My K5 Won't Turn Over
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rowdysr, Nov 11, 2001.
  1. Rowdysr
    Rowdysr Registered Member
    Nov 18, 2000
    20
    Whidbey Island, WA.
    My K5 Won\'t Turn Over
    On my way home from work tonight I stopped for gas, got back in the truck, depressed the clutch, turned the key, and nothing! I cleaned the battery cable ends, cleaned the connections at the starter - nothing. I have lights and the horn works. Could this be the ignition module? It was dark by the time I got in so I couldn't explore any further. Any hints will be appreciated because I would rather build an engine then deal with the electrical!
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Re: My K5 Won\'t Turn Over
    DOes the starter click at all? First make sure you have full voltage w/ a multimeter. Your best bet would to get a test light and see if you have power to the starter... if you do try turning the key and hitting the starter mildly w/ a hammer and see if it turns over. If this works the starter is bad most likely if all the connections were good at the starter. If you have no power there I would look at the clutch saftey switch and ignition switches. The ignition module will not cause a no crank condition.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  3. Rowdysr
    Nov 18, 2000
    20
    Whidbey Island, WA.
    Thanks for the info. I did beat the starter- no go. No noise either, like battery or solenoid. The alternator is working fine. I tried to jump it (full well knowing that wouldn't work)! LOL I just have nothing when I turn the key. I did consider the clutch switch and will check that out first thing in the morning.
  4. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    You might want to make sure all the wires are intact on the solenoid as well. You are right, electrical problems arer a b*tch. They can test you. Pick yourself up a hayes or chilton manual, they are extremely helpful.
    Shawnboy.
    If you are having too much fun it's probably illegal.
  5. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Same thing for me and none of that, I had full readings at starter, the short was in wiring from starter to ignition, so low readings at input voltage to ignition, had to replace entire wire from starter to ignition input because I couldn't find the bad section of wire. A true bit(*&amp;.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  6. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I didn't read too many of the replies cos my eyes are not working too well today, but did you check the safety switch on the clutch? Mine went bad on a truck I had years ago. I used a paper clip and black tape to fix it. My .2, hope that's all your problem is!
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  7. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Try the battery cables themselves. Even if the ends look good stuff can start forming in the wire in the center and then make go crazy fixing it when it's a wire. I just went through this not long ago and it was the negative wire. It was corroded in the middle but I couldn't see it (under the tape that was around it)... replaced it and it fired right up. Cut open the wire and it looked like crusty old toothpaste inside... so no wonder it wouldn't start............
    &lt;&gt;&lt;<a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>&gt;&lt;&gt;
    Suck Fumes Ford Boy
    I keep trying to lose weight, but it always finds me!
  8. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Just turning the key won't work. You'll have to get it on a serious sidehill, or try going over a really tall rock with one tire. I bet if you try hard enough, you can get it to turn over!!!
    Sherman, Tx
    <font color=red>The blazer's almost on the road....anyone got tree fiddy?</font color=red>
  9. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Thats works, thats how I turned my Jimmy over 6 times, steep hill and broken rear end :)
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  10. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    its not all that hard to turn it over. just go past what your flex can handel
    i blew my main seal.
    now my brain leaks
  11. Rowdysr
    Nov 18, 2000
    20
    Whidbey Island, WA.
    Thanks everyone I appreciate the input. I checked the clutch switch first thing Sunday morning - It had continuity. So I pulled the starter and off to the parts house I went. They tested it and it wasn't bad - IT WAS DEAD!!! I went home with a new one for free (I have a lifetime warranty) and in ten minutes I had it in and my baby was running! Thanks again for everyone's help!
  12. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Lifetime warranties kick ass!!!!
    Jim
  13. COOTER
    COOTER Registered Member
    Sep 25, 2001
    49
    SOUTH EAST GEORGIA
    IF YOU DONT MIND GETTING SHOCKED A GOOD WAY TO SEE IF ITS YOUR STARTER IS A SCREWDRIVER ACROST THE POST.OR WIRE IF YOU GOT IT.FOR NEXT TIME.
