my leaky 241 need help
Discussion in 'The Garage' started by George_Pimpdaddy, Apr 30, 2005.
  1. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    I finally found my leak in my transfer case the other day it turns out that its not the rear seal that i replaced but that the skid plate under the case rubbed a small hole in the bottom rear half of the case. So i need to fix this problem really quick as im putting a quart of atf in my tranny any time i go any where and its just pissing it out after the oil thins out. would something like jb weld work and will my transfer case be okay???
    thanks for the help :)
    1989 Chevy Silverado Blazer
    355/700r-4/241
    10 bolts with alburn posi in rear
  2. ktedesco
    ktedesco 1/2 ton status
    Mar 21, 2004
    365
    Colorado Springs, CO
    How big is the hole. I have fixed holes in tranny pans and oil pans with JB Weld before. I had good luck with it lasting but I was nervous about it. If the hole is small enough I would think it is worth a try. Just make sure you clean the area very good first.
  3. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    if its small it will work, also correct the rubbing issue, replace the worn trans mount or straiten the bent skid plate
  4. George_Pimpdaddy
    Oct 17, 2002
    1,306
    thanks for the info i thought that jb weld could do it also what should i use to clean the area before the fix???
  5. dave_90_blazer
    Jan 1, 2004
    688
    I would pull the t-case(easy -- 1/2 hour job) , flip it so the hole is up(so it won't drip), then scuff the area around it with sandpaper(or similar), spray it with brake clean a couple times, blow it off with air, , then JB Weld it, let it set up good before flipping it over or reinstalling
    you will need at least a quart of ATF(to top off the trans, might need some to fill the t-case as well)
