my lights look flicker like a strobe light????PLEASE HELP!!!
Discussion in 'The Garage' started by toomanytoyzz, Sep 6, 2005.
  1. toomanytoyzz
    toomanytoyzz Registered Member
    Apr 16, 2005
    27
    Havertown, PA
    I just bought a 72 Jimmy, and I'm having good old electrical problems. The lights pulsate when the car is running. Last night I blew my running/tail/instrument lights fuse. The headlights and turnsignals still worked, but also continued to pulsate. What could be the problem? I'm thinking alternator diode or the voltage regulator. Any info would help???? Oh yeah, you can hear the engine surge with the hood open when the lights flicker. It follows the same beat.
  2. Afireinside
    Afireinside Registered Member
    Jan 22, 2005
    61
    Aurora Colorado
    I had the same prob. I replaced the alternator and that fixed it.
  3. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    My guess is..
    I'd say altenator diodes or voltage regulator too,or perhaps a short in a major power wire,like the big red ones that go to the starter or from the back of the altenator...your 72 should be the last year with an EXTERNAL regulator--you can upgrade to the newer style integral regulator altenator without too much work..
    There are 2 hidden fuses near the radiator support on both sides under the hood,in the corners near the battery --made into the wiring harness are 2 rubber plug looking fuse holders--I think they are for the ammeter on the dash--if either or both of them blow,it can cause weird things to happen..my 72 K5 had them,and when one blew I lost some of the gauges in the dash,and the lights flickered..might check them first... :crazy: :crazy:
