My live oil gauge is leaking, what do you use??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by calvin, Mar 1, 2002.
  1. calvin
    calvin 1/2 ton status
    Oct 23, 2000
    152
    Brownstown, Michigan
    For the life of me I cant get this stup plastic oil line to not leak. I've replaced it like 3 times. It doesn't leak at the guage just where it goes in the block. Should I look into getting a copper line setup, like what was original?
    What do you run?
    <a target="_blank" href=http://irocz.cz28.com>http://irocz.cz28.com</a>
    79' Chevy Custom Deluxe shortbed K10, 396 ,pics on site
  2. calvin
    Oct 23, 2000
    152
    ttt
  3. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I had this problem most recently when I forgot to reconnect the line in mine, and did an emergency reconnect. I believe you have to crush the cone sleeve around the line to get it to stay in there and not leak. You'll probably have to go buy another small one of the installation kits that have all the fittings and hose (keep a spare too, the cone sleeves are a pain in the butt to reuse; I've had to do it on the side of the road, which is 3x worse than just having to do it)...
    Take the cap that you screw down over the fitting, insert the cone in it, point end facing out. Hand screw it down over the fitting to measure it. Count the exposed threads on the fitting, remove it, and slide the hose through it. Place the hose into the fitting on the block, slide the cone down it, then screw the cap down over it. Keep screwing the cap down until you reach the point you measure, then give it a couple more turns with a wrench.
    Basically, you want to crush that little cone sleeve around the line. That's the only way I've ever gotten them to stop leaking.
    Ratch
    CK5 album &lt;-- New Wheelin' pics!
    This is not a new signature.
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Or better yet order a stainless bradied line kit from Summit. No plastic hoses to melt and leak. A friend lost his new 350 because of a plastic oil pressure line.
    My.02,
    John
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  5. calvin
    Oct 23, 2000
    152
    ahha....there we go. Sweet suggestion, I didn't know they offered one. Thanks alot. Don't want to lose my 396 to some $5 line.
  6. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    solution. smash it with a sledge and buy an electrical one. I had nothing but problems with three live oil gauges in my vehicles.
    </font color=blue>
    <a target="_blank" href=http://blueknight.alloffroad.com>http://blueknight.alloffroad.com</a>
    "If First you don't succeed, Destroy all attempts you've tried"
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wouldn't trust my engine to an electric gauge. You can if you want.
    Tim
  8. calvin
    Oct 23, 2000
    152
    I agree guys, but I'd like to keep my tach dash all original, and I don't see any other way.
