My Motor Thread
Discussion in 'The Garage' started by NoReGrEtS, Feb 28, 2007.
  1. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    :D :D
    I love getting stuff in the mail.
    Can you guess what I will be doing?:D
  2. Dudge
    Dudge 1/2 ton status
    Sep 9, 2006
    351
    Kentucky
    Awesome. What ya working on?
  3. NoReGrEtS
    Nov 7, 2005
    848
    Im going to build me a motor:D . Just a 350 .030 over with some vortec heads, and a 4x4 cam. I want a make it a good strong motor, but not over the top well Im trying not to go over the top still want the mpg and not gpm:D
  4. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
  5. Dudge
    Sep 9, 2006
    351
    Kentucky
    Sounds like a good little project. I'll be doing that some day hopefully.
  6. NoReGrEtS
    Nov 7, 2005
    848
    Well I'm going to make this my motor build thread. Its going to take a little bit to put to gather,but it should be worth it in the end.
    here are the spec I'm shooting for but not set in stone
    350, .030 over w/molly rings
    cam shaft, undecided
    double roller timing chain
    vortec heads
    roller rockers
    edlebrock intake
    edlebrock off road carb
    headers, have some camaro ones,dont know year but will see if they fit
    and dual or single exhaust not sure yet
    I'm building the motor to swap with the smoking 305 I have now.
    here a pic of what I started with
    and some 882 heads
    Thanks to BKinzey for the motor.
  7. NoReGrEtS
    Nov 7, 2005
    848
  8. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    Not need ,for what you are building it would be a waste of your money.
    I use to work at an automotive machine shop & we put out some pretty strong small blocks & alot of them were only two bolt mains. I've never personally seen a small block break a main cap . We had a guy bring in a 350 that had broken the crank at the 2nd main journal ,the cap was intact (2 bolt cap) but the block was cracked straight up the middle of the front of the block from the #1 main oil hole to the first cam bearing oil hole . Just my .02. Good luck with the build.
