My nephew blew up his tranny in his '95 4x4 - What years will work?
Discussion in 'The Garage' started by DPI, Mar 29, 2004.
  1. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    My nephew blew up his tranny in his \'95 4x4 - What years will work?
    What years will work in a 1995 xtra cab 1/2 ton 4x4? He has a 4L60E. Will a later model tranny work? Say 1999-2001?!?!
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    Re: My nephew blew up his tranny in his \'95 4x4 - What years will work?
    it has to be from behind a 350, so 92/93-98(went to the 5.3/6.0 in 98/99)
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    93-98 4l60e will work. 92 transmissions were not electronic controlled. 95 is a tbi motor with a 4l60e or 4l80e, my 95 had a 4l80e. Also from behind a 305 or 454 would be fine doesn't have to be a 350. Though 454 would come with 4l80e.
  4. dave_90_blazer
    Jan 1, 2004
    688
    actually, both the 4L60 and the 4L60E were avalible in 92, and you're right about the 454, I forgot about that, just no newer then 99(no LS1 style trans)
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it needs to be from 93-95. in 96 the case was changed to a 2 piece case and they also changed the output pattern on the 4x4 cases. the 96 on is a 6bolt round instead of the 4 bolt square
  6. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Thanks for the replys! That helps a bunch. /forums/images/graemlins/waytogo.gif
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    both were available in 93.
