my new 87 K-5 with a 6.2
Discussion in '1982-Present GM Diesel' started by KRUM, Jun 27, 2002.
  1. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    alright guys got me a diesel(first one) and don't know any thing aubout them /forums/images/icons/confused.gif first off when you first crank it up after it's been sittin it smokes pretty good but quits within 15 seconds and doesn't smoke any more when i crank it unless it sits over night. it will also smoke when i lay into. second it has 31-10.50-15 tires and my spedo is 15 mph off /forums/images/icons/confused.gif i came home up the steepest part of the mountain with the ac on and the temp got up to 230 is that good bad or what? also it pulls to the left when i mash the brakes and there is a lot of play in the steering
    thanks,
    krum
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Congrats!
  3. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    A little smoke with cold engine is normal. Also under full load the Diesel may smoke.
    230°F is definitely too hot. Do you have sufficient cooling water, is the radiator dirty or broken, the thermostat functioned correctly (or is a winter thermostat inserted)? Also the water pump, Visco clutch or a cylinder head gasket could be defective.
    With the steering it is as all Trucks. Examine first all joints.
  4. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    what about my spedo bieng off that much? also i checked the smoking again this morning and it did it for 2 minutes it was a white smoke if that helps and the exhaust on the drivers side cleared up faster than the passenger side does this mean i need glow plugs? also lets talk aubout turbos!!
    thanks,
    krum
  5. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    The technical explanation for the white smoke: If the engine is still cold, finely injected Diesels settles down at the metal and forms droplets. These droplets cant burn and thus the engine sucked too much air in. Too much air = white smoke.
    The driver's side of your engine warms up faster than the other side.
    Because of your speedometer I cant say anything. I believe its ratio dont fit your tires.
  6. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Is your speedo fast or slow?
  7. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    its 15 miles slow
  8. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    Are your original tires 235/75 15? Then the ratio of the speedometer is too long around 7%. There are the gear wheels for it to buy and you need one with 2 teeth less.
    38 teeth = bright blue
    37 teeth = bright red
    36 teeth = white
    39 teeth = dark brown
    35 teeth = pink
    34 teeth = natural
  9. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    15MPH slow at what speed? Speedometer error is a percentage, not an absolute value. Unless the speedo itself is broken, it will not be off the same amount at all speeds.
  10. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    at i clocked myself on one of thosespeed signs on the side of the road i was registering 35 it said i was going 50
  11. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I just did that. I was doing 45 and the sign said I was doing 35. I wouldn't trust them signs.
    If I am on the interstate I use the chronograph on my watch to time 1 mile. 1 mile in 60 seconds means you are doing 60. 55 seconds means 65 mph...50 sec means 70....etc.
  12. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    Now I am completely confuse. /forums/images/icons/confused.gif
  13. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Sometimes electronic signs, that are equipped with a radar gun, are put in high traffic areas or places in which people tend to speed. As you approach the sign it displays the speed at which you are traveling. but I do not know how accurate these signs really are.
  14. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    another question guys when you change your fuel filter should you prime the new one?
    thanks,
    krum
  15. josephn
    josephn 1/2 ton status
    Nov 3, 2000
    138
    Utah
    I just fill mine with diesel fuel before I put it on.
  16. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    The Diesel Page
    Might want to look into this website and becoming a member. These people live and breathe 6.2 Diesels. The price is small compared to the wisdom that the site and members have.
  17. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    what is the best abanks turbo or a whipple supercharger for my 6.2?
  18. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Banks is half the price, That sounds better, but dont know in the way of performance.
