My new Ebay Purchase
Discussion in 'The Garage' started by dabears73k5, Oct 28, 2006.
  1. dabears73k5
    dabears73k5 Registered Member
    Jul 27, 2005
    52
    El Segundo, CA
    :D
    Items in this auction: Four (4) Used Tires per Lot
    Tires Manufacturer / Model: Michelin / Military XL (Radial)
    Tires Size: 11:00 - 16
    Tires Actual Size (Aprox.): Height 38 Width 11
    Tires Tread Condition: 75-85% Tread Remaining
    Tires Specifications: Load Range E
    Max Load Single: 4520 Lbs at 80 PSI
    Do you think a DANA 44:doah: can hold up to these if this is my daily driver and sees mostly light trail stuff. I am new to offroading and will most likely do easy stuff and don’t plan on running my stuff to hard. I have a dana 44 and 14ff both with 4.56 and open, powered with a 350/350/205. I plan on putting a Detroit in the rear and prob a truetrac in the front. Do you think that these axles will hold up to the 38s :confused: , they are only 11” wide. I plan on putting in D60, however I can’t find a good one to rebuild for a decent price so until then I will run my ¾ ton drivetrain. Thanks for the input
  2. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,615
    71
    Living in a dump, VA
    i think you will be just fine...refer to the post to 60 or not to 60
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    I personally wouldnt given the weight of military tires. they are much heavier than a standard 38" tire. Never mind the axle itself, your putting alot of stress on things like balljoints, bearings etc. To hold you over till you get a 60 you should be fine.
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    If you leave it open with those you will eventually have trouble.If you lock the front, you may be in for trouble fast.
