my new motor got a tick
Discussion in 'The Garage' started by the hulk, Nov 16, 2003.
  1. the hulk
    the hulk Registered Member
    Feb 9, 2003
    40
    phx az
    hello all . well i had it running for about two week now and from the frist day it had a tick and it does not sound like a lifter tick its coming from the right side if you sanding over the motor it sounds like it coming from down under like in the exhaust pipe but from under it it sound like it coming from up top i put stick up to each header tub and the ones on the right bank at the back of the motor make a lot of niose i don't think its a exhaust leak and i don't think its a lifter ticking could it be a valav sticking any thouts on what it mite be
    web page
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Was that one sentence? /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    check the rockers....
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    dood, randy, breathe LOL...seriously, new distributor or used? could the dist be making the noise??
  5. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    Loose flywheel bolts? sounds more like a rod knock but Id check it out. Torque convertors make some neat noises to owhen they start to come apart.
  6. the hulk
    Feb 9, 2003
    40
    phx az
    the distributor is new every thing but the alternater is new . it dont sound like its coming from on top of the motor like lifter or rockers but more like from in side it but not in the bottom end of the motor, if a valve was sticking could you hear it throw the exhaust
  7. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    Take a long screwdriver, put the tip against the valve cover, and the handle end put it against your ear. If it's a rocker, you should be able to hear and tell which one it is. If it's an intake valve misadjusted, you won't hear it in the exhaust.
  8. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Does the motor have roller tip or full roller rockers? My 454 has roller tip rockers and they have a LIGHT tick. I can barely hear it over the exhaust.
    Chris
