My new motor is a dog
Discussion in 'The Garage' started by Geno, Sep 14, 2003.
  1. Geno
    Geno Registered Member
    Nov 18, 2002
    52
    Dorchester, Nebraska.
    Need some suggestions here, I have a rebuilt 350 with flat top pistons, edlbrock performer cam and intake, (yea I know the cam sucks, but that is what it has) 350 turbo tranny, 456 gears in 3/4 ton axles, 35inch tires. New distributer, wires plugs, has the original quadrajet carb, This thing is a dog, seems like it is always behind trying to catch up when you nail it. Its a dog , was expecting to a least break the tires loose with little effort NOT. Any suggestions to what I could adjust? Have played with the timming, not a big difference, timing is sitting a 9 right now, could the carb be causing this? No snap at all to the motor, any suggestions would be appreciated, thanks for your time.
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    at first, i would bumped the timing up and down to see if there is a timing related problem. If this is a new distributer, does it have an adjustable vacume advance??. Are you sure the cam timing is correct? I hate q-jets. Just my personal fealings. they are harder to tune for performance than a holley or edelbrock performers. do you have access to another carb? It could be alot of things. It will take some patiance to figure it out. Does it blow any smoke when it's doggin? The performer cam/intake combo should produce a fair amount of low RPM torque. enough to shread the tires!
  3. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    have you looked at the exhaust, it may be pluged/restricted from a bad cat, bent pipe, or a pluged muffler.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Headers really woke my motor up. I just have flat tops, port matched heads, Performer intake, junk carb, and an RV cam. I couldn't start out in true first gear on my SM465 before. Now that I have headers I make more than enough torque and it starts out fine. 2.73s and 32s aren't fun.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't think your truck is a dog, I just think you're in dreamland thinking you're going to smoke a set of 35s off when nailing a 350.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'm not a big Chevy 350 fan anymore. Looking for a Big Block myself.
  7. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Let it break in maybe? My new longblock was a dog first week or two, but after letting it break in, it started picking up... maybe im hallucinating.
  8. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Hahahaha! /forums/images/graemlins/rotfl.gif I wasn't gonna say it. /forums/images/graemlins/grin.gif
    I've got a 350 powering 35's with 3:73's and i can bark the tires when taking off from a stop sign sometimes...
    I don't think you'll be doing any tire roasting, but mine isn't a "Dog" when accelerating.
    I finally came to terms with the fact my blazer isn't a dragster and had to buy another chevy for the sole purpose of going out and smokin the tires. /forums/images/graemlins/grin.gif
  9. 78GMC1/2TON4x4
    78GMC1/2TON4x4 1/2 ton status
    Mar 10, 2003
    167
    Mount.Angel, OR
    Ditch that quadrajet, i still have the stock one on my truck and i think its horrible....steming to most of my horrible running problems /forums/images/graemlins/truck.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Q jet might have an internal vacuum leak like most of mine. When my 350 was in my 1 ton it ran horrible. The only thing that's changed when I put it in the big truck was timing curve, Edelbrock intake and carb, and the exhaust (dynomax headers, flowmasters, duals). It feels more powerful in my truck with 38s than it did in the other with 32s.
  11. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    What do you have the timing set at???? That was my problem after I rebuilt my motor. I am not going to say what my timing is set at because of all of the criticism I got last time. I can't explain why my truck likes so much timing but it works and will smoke the tires from the start and bark them again when it hits 2nd gear and gets almost 10 mpg. /forums/images/graemlins/thumb.gif
  12. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Dude, with my 350, if I revved the piss outa it and dropped the clutch, it was all it could to to just chirp the tires (35's and 3.73) now with my 454, if I do the same thing, I will leave 2 black streak about 30feet long, and that is with the new 37's I can't wait till I regear...
    But I would check out the timing, and run it hard for a while and check the plugs, see if they are running on the lean side...
    Chris
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My timing is at 8* right now but I can bump it up some more, however, I have an adjustable vacuum canister on mine and my vacuum advance has a limter cam on it so I wouldn't recommend you bumping yours to 10 or 12 like I plan on doing.
  14. Geno
    Nov 18, 2002
    52
    Thanks to everyone for your replies, My timing is set at 9 right now, Called Edelbrock, the man told me I had to use the timing chain listed with the cam, so 80.00 later and 2 hours to install it, it seems to be alittle better but not real noticable, havn't had a chance to mess with the timing very much yet, hope this is the answer, Will be looking into a new carb also, crawled under the beast last night to measure my exhaust, it's not even 2", this could be a problem too, would like to put some tri-y headers on but funds are limited. Thanks again for all the opinons. will check things one by one to sort this out. later /forums/images/graemlins/cool.gif
  15. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Plugged exhaust could be a problem. How does it run compared to the last motor?
  16. Geno
    Nov 18, 2002
    52
    Runs exactly the same, that motor had 180,000 on it!
  17. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Put a bigger exhaust system on it and I bet you'll see a big difference.
