my new ride
Discussion in 'The Garage' started by eightyone, Oct 3, 2004.
  1. eightyone
    eightyone 1/2 ton status
    Apr 25, 2004
    292
    long island
    i just picked up a 1970 shortbed pickup, manuel tranny, not sure ont he transfer case. its got a driveshaft going out of the transfercase, and to a bracket, with another driveshaft coming out of that. whats the deal? can i take that braket off and just run a longer driveshaft for a better angle? and also, its got 56 inch springs int he back, is that normal for a 1/2 ton shortbed? the front rear spring mounts are some custopme made jobs that i am gunna take off, and i have a rear lift springs from a blazer, so i will probally just move them back. thanks.
  2. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    pics, pics /forums/images/graemlins/thumb.gif
  3. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    Sounds like you have a two peice driveshaft with a carrier bearing between the two--I was never a fan of those,the carrier bearings are a weak spot--they made the same trucks with a regular one peice shaft,dont know why they felt the two peice one was nessasary,perhaps to get better driveshaft angles with certain tranny's.You could try using a one peice shaft and see if it vibrates--I'm not sure of the stock spring lengths,but a Hollander interchange book they use at the junkyards has the lengths and widths of the springs listed. /forums/images/graemlins/crazy.gif
