My New Shocks From Poly Performance
Discussion in 'The Garage' started by crazyhole812, Oct 14, 2005.
  1. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    i got the 15" travel shocks from poly performance. they have a bumpstop on the end. the problem is, i don't know how much it will squish down under the weight of my truck. when not compressed there is only 12 or 13 " of rod showing. does anyone have these shocks? i'm just trying to figure my mounting height. thanks
  2. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    drive up a ramp or something. depending on your springs you will need more of one thing. either up travel or down travel. with my 63" springs i need alot more down travel. it only goes up half as much as it goes down...you need to flex it to see where to mount them.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    BBCS shocks? Jekbrown has them.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    You need to measure like Psychotic said. Not all springs and suspension work the same.. On the uptravel though, I would mount them so that when the spring is perfectly flat, you are bottomed out on the shocks bumpstop. That will keep your springs from goign negative arch and last longer. :thumb:
  5. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    I also agree with the other two. I only have about 3" of up travel on my rear shocks and 9" of down travel. The fronts are the other way. I am running the 4" lift springs and i needed more up travel then down so measure it out and go with it.
    Let us know how you like the shocks!!
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ya, I lucked out. Running 6" Superlift Superrides in the front with the GAB G63438's. Used the stock mounts and my shock bottoms out on up travel just as the springs goes a hair negative!
    I would like to hear about them also. Have heard nothing but good things about them!
  7. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    all depends on your specific suspension... you can't get measurements from anyone else, you'll have to ramp/measure your rig yourself. With 52s up front I have minimal up travel, which is fine, leaves lots of shock travel for mad droop. :grin:
    j
  8. crazyhole812
    Jul 6, 2005
    228
    missouri
    I was mainly wondering how much the stop will squish down the bumper is like 2 1/2" will it squish down to 1"?
