my new tag along trailer!
Discussion in 'The Garage' started by Thumper, Nov 16, 2002.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Just picked up my 'new' trailer. Utility/ camper with a small config change. Neat huh? They are ex-military 3/4 Ton, rubberized top, wooden/ metal superstructure, hydraulic inertia brakes on the tongue, individual park brakes, tilt bed, pintle hitch... /forums/images/graemlins/smile.gif They run 14BFF hardware, brakes, drums, wheels etc.
    Nice huh?
    Mike
  2. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    Cool
    where did you get it?
    how much $$ ?
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    That thing looks nearly indestructible! /forums/images/graemlins/cool.gif The dog seems somewhat aprehensive about it though. /forums/images/graemlins/wink.gif
    Is there a way to lock out the brakes? Backing up a hill with those can activate the brakes, making it pretty hard to go up! /forums/images/graemlins/shocked.gif
  4. Grim-Reaper
    7,385
    Atlanta
    That thing is sweet. I had looked at them before and even found some local for $300.
    Did somebody conver it to use 14 bolt stuff or is that the way they came? I seem to recall the one I had looked at had the big lug pattern that was like a Duce. It my have been the 1.5 ton version I was looking at though.
    I was looking at swapping the axle with one that had the same lug pattern that I run on the truck.
  5. Thumper
    1,582
    Alberta Canada
    They are Canadian military versions. I am not sure if you guys ran them as well or not. Probably cause they went as a set with the CUCV 5/4 trucks. A few of the guys in our club went in on an auction and picked up some. They are giving a great deal for the guys in the club as first dibs! I got it for 400, they paid a lot less than that for em.
    The wheels and running gear is the way they came. The ones you said about Grim were the larger ones, with the 2.5 ton 6x6 wheels I guess.
    And the brake does pin to disable it, cause that would be a royal pain tryin to back it up while the brake is trying to stop you.. hehe'
    Mike
  6. RATAH
    Aug 10, 2002
    576
    Franklin,Ohio
    where can we buy em in the states?
    any links
  7. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    Grim there is also a 1.5 ton that is easier to find than the 3/4 ton and more managable than the 2.5 ton. They are big enough to put a truck on, I measured one when I bought the Dodge, but very high and single wheel. The were built to haul large generators. You could do a spring under w/ a smaller axle, but it would still be single wheel.
