My new to me engine #'s
Discussion in 'The Garage' started by 55Willy, Feb 10, 2006.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    friend just dropped off a motor for my 68 burb.
    was told it was a 400 out of a 78 van.
    at 1st look it says 400
    no 3rd freeze plug or boss on the sides and no cut balancer like a 400 would have.
    but the rear casting # says 3951509 swhich is a 400
    the front is FO322TLT with C7U186440 under that
  2. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    De code..
    The "TLT" is the engine code..all my books are out in the shop..I tried Moretec and a few other sites,they only list casting #..yours IS listed as a 400,so I'd say you might have a 400,but its got the wrong balancer on it..or maybe its been reworked with a 350 crank??...does the flex plate have any balance weight on it..??..:confused: ---it wouldn't be the first 400 I've seen or heard of,with the wrong balancer or flexplate on it!..
    The 400 I have is from a 78 suburban,I yanked it to put in my 74 K20 years ago,and saved it..never took the codes or numbers off it..guess I'll have to look tomorrow in the daylight and see what mine is!..I'll see if my books list a
    "TLT" code too...and let you know,if no one else comes up with an answer first..I don't have many truck codes in my books,mostly cars,that begin with "C",like "CTM",etc..but I'll look..:crazy:
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    Made in the Flint engine assembly plant on March 22, 1978
    Engine is a 175 horse 400, from a Chevy Van
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    thanks guys, looks like a need a fluid dampner then. :)
    I already found a new flywheel for the 465 set up to run this 400 :)
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i would seriously look into that balancer, probably even pull the engine apart because of it. if it is in fact a 400 rotating assembly, a neutral balanced damper on it could cause all kinds of problems. specifically in the area of the main bearings.
    with that said, did you get my PM on Thursday? i need that bellhousing ASAP!
  6. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    Didn't show...
    My book lists a"TLS,and a"TLR"(my 78 is a "TLR") for 400 SB codes in 78..but this is in a Blazer/C/K Series book,a van might have the code a bit different..I'd say its definately a 78 400,the alphabetical order of the code "jives" with the ones I listed ..it just has the wrong balancer,or a different crank perhaps..I'd look inside and make sure it didnt shake itself apart too.,and see if it has a 350 crank in it,making it a 377 cid..
  7. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
