My new welder showed up today!
Discussion in 'The Garage' started by yunit, Mar 21, 2005.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    :weld: :weld: :weld:
    Can't wait to fire this puppy up. :D
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Nice! Whats the specs on that badboy?
    John
  3. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    Power MIG 255C
    Power MIG. The Professional's Choice
    List Price:2114.00 (USD) *See Details
    K2416-1 Power MIG 255C 208/230/1/60
    The Power MIG 255C sets the standard for MIG and flux-cored welding in industrial production, job shop fabrication, maintenance or repair work. Diamond Core Technology™ delivers a wide voltage sweet spot across the welding range, low spatter levels and a forgiving arc on steel, stainless and aluminum -- even for demanding out-of-position work. It's Spool Gun Ready, so its fast and easy to tackle difficult aluminum applications. Exclusive 115 volt auxiliary power means you can power lights, grinders and chargers right where you work! And, the rugged cast drive with patented Split Wire Guide systems and tachometer feedback ensures trouble-free wire delivery. Add the extra length 15 foot gun cable and a host of innovative convenience features and you begin to understand why the Power MIG 255C is considered The Professional's Choice!
    Advantage Lincoln
    • Diamond Core Technology, a patented choke design, delivers:
    - A forgiving arc, even with large stickout changes
    - Excellent out-of-position arc action
    - A wide voltage sweet spot at a given wire feed speed
    - Low spatter
    • Rugged cast aluminum industrial wire drive features dual driven rolls, easy-turn numeric tension indicator, brass-to-brass gun connections and Lincoln’s 100% wire-supporting split wire guide system.
    • Digital meters display, preset wire feed speed and voltage, and actual amperage and voltage while welding.
    • Generous 15 ft. (4.5m) gun and cable assembly makes it easy to reach your work.
    • The most economic spool gun solution in the 250A category – costing hundreds less.
    • Three year warranty on parts and labor (90 days warranty on gun).
    Hot New Features:
    • Spool Gun Ready – The Power MIG 255C has the electronics built-in to drive either the Prince® XL spool gun or the Magnum® SG spool gun. A second gas solenoid is also built-in for spool gun use.
    The Power MIG 255C features a 115V auxiliary receptacle (208/230V model only) to power a grinder or other auxiliary equipment in your work area. :cool1: It actually has two outlets. :cool1: :cool1:
    Physical specifications
    Weight:240 lbs.
    Dimensions (in) H x W x D : 31.8 x 18.9 x 38.8
    Welding Specifications
    Rated CV Output Amps/Volts/Duty Cycle
    250/26/40%
    Output Range
    30-300A DC
    Wire Feed Speed Range (IPM)
    50-700
    Wire Feed Speed Range (M/MIN)
    1.3-17.7
    Solid Wire Size Range
    .023-.045"
    Cored Wire Size Range
    .035-.045"
    More info
    Competitive comparison
  4. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I'm hating you right now! lol jj man, thats a sweet welder.
  5. mcinfantry
    mcinfantry 1/2 ton status
    Dec 2, 2003
    308
    bought the same welder today...... hope to fire it up tomorrow or sunday!
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    will be buying the sameone asap. Same unit we have at school, love that thing.
  7. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    jealousy has now set in!
    All I got is my old miller 235 mig, and that old Hergenbraectflokinwhatever 400 amp arc stick monster. oh well it works!
  8. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Is it better, or comparable to the miller 251?
  9. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    I'm drooling just looking at that thing.
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    it is Lincon's counterpart to it. Better? Eh I think the Miller/Lincoln thing generally boils down to what you like better. I like Lincolns, even though I've never had a problem with a Miller(or used them extensively). I just love this machinea fter using it at school. Ours isn't the C(no 120 outlets on it). I'll likely get the C whenever I get around to getting one. I had a Lincoln 175 and this machine blows it away in adjustment and power. I can lay SUCH a nice bead compared to the 4 or 5 preset settings machines. I never realized what I was missing.
    Oh Pete, I never asked, what did you pay for this thing? Retail is 2100 I see just wondering what you got it for. We have a local dealer that usually pretty good under MSRP. There was a used on on Ebay very recently for $1000 I really wish I had jumped on.
  11. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Sexy:bow: I want one now:D
  12. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    What he said....:bow:
  13. 2High4U
    2High4U 1/2 ton status
    Aug 20, 2005
    542
    Felton Pennsylvania
    awsome welder congrats!
