my newly aquired relays....
Discussion in 'The Garage' started by RootBreaker, May 22, 2004.
  1. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    this is also under tech article but I dont think many people read them.. /forums/images/graemlins/whistling.gif
    aight I got mine from a Buick.. Im drawing a blank here.. brain fart... buick .. that has eight or something like that on the back????? /forums/images/graemlins/dunno.gif
    anyhow I am drawing a blank cuz checkout this deal...
    $15
    I pulled it
    8 relays and 2 spares
    15 fuses!!!! and checkout the size!!! probably dont need that many or size.. plus I dont know how they are wired.. but ill have to figure that out....
    anyone want to hook a brotha up on how to wire this dagone thing???
    clickeys to big and i mean big pics... /forums/images/graemlins/peace.gif /forums/images/graemlins/woot.gif
    http://rootbreaker.no-ip.com/PROJECT_NJLEGAL/Roll_bar/Relay.jpg
    http://rootbreaker.no-ip.com/PROJECT_NJLEGAL/Roll_bar/Relay_Fuses.jpg
    can anyone help me with the relay part numbers?
    Im trying to figure out what amp / watts they are... so i dont load too many KC's on em.. or other stuff...
    25553347 x 5 - AC Delco p/n 158386 – Horn Relay
    12077867 x 2 – Blower, ABS, Fuel Pump, Headlamp, Horn
    12077864 x 2 - Blower, ABS, Fuel Pump, Headlamp, Horn
    the x is just how many i have.. my side note.. and the what it is for is what i have found searching the web..
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Ahhh, I see that at least someone has read my article. /forums/images/graemlins/wink.gif Nice score! /forums/images/graemlins/thumb.gif
    If you unwrap the wiring harness, it's pretty easy to trace which wires go where. Each relay will have a couple of fat wires and a couple of skinny wires attached to it. The fat ones are for powering the switched circuit and the skinny ones just power the coil that switches the relay. Those look like they're all 30-amp relays, so each relay will easily power a pair of 150 watt KC Daylighters. /forums/images/graemlins/cool.gif
  3. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Cool, I see I'm not the only one to jump on those things.
    I've pulled a couple of smaller ones, but next time I'm in the yard I'm gonna look for a larger unit like that.
    I know the newer park aves and such have nice big clusters like that under the hood too.
    Way to keep you GM all GM! /forums/images/graemlins/waytogo.gif
  4. RootBreaker
    Nov 29, 2001
    5,117
    173
  5. skratch
    Oct 28, 2003
    1,646
    Gorveport, OH
    Too bad I have a mac at home and can't look at Visio files.
    I'm not to bad with it, we use it a ton at school for all the network design projects we work on. /forums/images/graemlins/rolleyes.gif
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    it is setup as a html file... but i used visio.. then saved as a html... /forums/images/graemlins/whistling.gif
  7. skratch
    Oct 28, 2003
    1,646
    Gorveport, OH
    DOH!
    Maybe I should looked a bit harder at the link.
    Looks good.
    But. . . .
    I would run 3 lights on the top bar on one and the other two off another so as to only use 4 relays, but that's just me.
    I kinda like the idea of three lights on one switch rather then the way you set it up.
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    That is a nice looking setup. I make my own relay boards from time to time with circuit breakers and so on but they always take up more space than that.
