my noise is getting worse...*update* *Solved*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Sep 18, 2002.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    Below is what the problem was, butluckily it was only a u-joint. IT was a Brute Force ujoint thatwas 1 year old w/ sythetic grease, what happened was the cap on 1 end broke, butdidnt come out, however all the bearings did... go figure, so im fixin it after this post
    phew what a relief!
    ok well i had that *ding* comming from when i put it in Rev and when i put it in Drive, now when i back up the *ding* goes *dingding* rapidly! /forums/images/icons/crazy.gif
    and then sometimes when i go fwd at a slow pace it does the same thing. /forums/images/icons/crazy.gif
    what is that and how do i fix it?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Re: my noise is getting worse...help
    U-joint maybe? can you tell where the noise is coming from?
  3. Grim-Reaper
    7,385
    Atlanta
    What transfercase are you running? That sounds just like what my 79 did when that POS Super wench 203 part time kit didn't have enough shims in the tail shaft to keep it tight.
  4. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    My truck made noises like that when BOTH rear uJoints were toast. check out those ujoints
  5. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    Definitely try to find out where the sound is coming from.
    Also, take a close look at your driveshaft and especially the ujoints.
    Can't image there'd be anything separating and banging something as the shaft goes around, but I had a similar problem when I went into four-wheel drive. Turned out to be the tranny mount and the front drive shaft whacking the subframe.
  6. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    well when my dad was under the car when we were trying to figure out what it was, and he said its coming from the Differential housing.
    but sounds like the dings are comming through the driveshaft as well
  7. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    i have either a 205 or 208, one of the 2. isnt one of them really good?
    well i have the not as good one.
    it was stock in my 85 automatic w/ corpertate 10bolts and i lowered the t-case with the stock spacers....
    where do i get shims how do i put it on?
    i have a 4in susp lift w. 1in add a leafs all round, and ive had it for bout 1 1/3 years and it just started doing this this month
    and i replaced the u joints on the driveshaft 1 year ago
  8. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    its a 208
  9. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Do you grease the u joints religiously? I mean after everytime you go wheelin'? I blew a joint that wasn't three months old because of lack of maintanance. One year old u joints in a truck that's wheeled regularly are bound to fail without good maintanance. I've had my truck just over a year and I'm on my third set.
    John
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Maybe jack up the rear so that the tires are off the ground and then put the trans into neutral. Then spin the driveline around. You can also wiggle the driveline to death and see if you can find a bad joint. If you dont have any luck you could pull off the rear driveline and spin the rear tires and see if its the rearend. Good luck.
  11. Grim-Reaper
    7,385
    Atlanta
    Pull the diff cover. I think your rear end is going out. It can transmit noise to the driveshaft.
  12. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i agree with grim pull the diff cover and see if you have any chiped or broken teeth on the ring and pinion
  13. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    they have synthetic grease so it doesnt need greasing
    there are grease nipples
  14. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    what do i look for when i pull it off?
    how can i tell if its blown?
    and what do i do to fix it?
    theres some more questions..... this thing is buggin the hell outta me
  15. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
