My one-evening Q-Jet rebuild
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blue85, Mar 15, 2006.
  1. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    I discoverd a couple of days ago that my poor idle was due to the carb leaking fuel into the intake manifold. Really, I've slowly noticed more of a gas smell in the garage over the past couple of years.
    So I decided to do an evening re-build. You know, tear into it after work and then drive it to work the next morning. What was I thinking?:doah:
    It actually wasn't too bad, but I got a little anal and started painting parts, which of course adds cure time. As soon as the parts were cleaned, I used JB Weld on the wells in the base of the carb. I replaced the gaskets, float, needle, seat, and accelerator pump seal. I also noticed that my main rods were a little bent, so I carefully straightened them out. One of the idle mixture screws was a little chewed on the end, so I filed it into the original taper. I had just replaced the choke pull-off and fuel filter a few weeks earlier.
    The second pic shows some of the epoxy. I will sell this carb once I get injected.
    My screw up happened during re-assembly. I pinched a vacuum hose between the throttle body and manifold gasket:doah: Easy enough to fix, but it squished the gasket there and caused a big vacuum leak. I couldn't get the truck to run for more than a few seconds, which makes troubleshooting hard. Finally I set the idle way high to keep it running while I ran in with my stethoscope. Some silicone fixed the leak and I went on to tune the idle mixture.
    This was the first time my idle mixture screws ever did anything:D The idle is smooth at 500rpm in gear. This is also the first time the vacuum gauge ever read 22 at idle. I got to bed late, but it ran great on the way to work this morning. The sweet taste of success.
  2. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    congrats! nothing like a job well done...
    i use to do it as a little sidegig.. rebuild carbs on the coffee table at night. :haha: pretty good coin for sitting there watching tv & drinking beer... and it was usually boat quads, so pairs meant double the money... :wink1:
  3. tiny2085
    tiny2085 1/2 ton status
    May 14, 2004
    160
    Two-will-uh
    how did you set your idles screws ? How many turns out from all the way in ? Is it a stock motor ?
  4. Blue85
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    I am close to 4 turns out right now. I started at two and kept bringing them both out half a turn at a time. I will mess with them a little more this weekend, my first goal was to just get it driveable. The engine is a Goodwrench 350. Tall air filter, headers, duals, nothing radical.
