My pistons sure have alot of play in the cylinders
Discussion in 'The Garage' started by mountainexplorer, Aug 1, 2004.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Finally pulled the heads off the 454 that was in my Orange Blazer from February through July.
    There was alot of hardened nearly crystalized oil deposits on the pistons, and I can take nearly all the pistons and move them from side to side in the cylinder bore.
    #3 Cylinder wall has a few spots where it looks like small sections are pitted... like little low spots where looks like the metal is bad.
    Any guesses as to the demise of this motor?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Mud got into the motor and ate the crap out of the cylinders.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Sounds like it's time too bore it and install some new pistons.
  4. mountainexplorer
    Nov 14, 2001
    4,903
    Oh, and I forgot to mention the several cam lobes going flat, and huge divets in the bottom of the lifters.
    And yes, some mud/water mix splashed up a few times and soaked/drenched the open air filter. I put a closed one on a while back.
    I'll also admit to running this motor hard. I don't intend on using this block for now. I'll set it aside, and someday take it .060 over.
