my rear brake lights wont turn on!?!?
Discussion in 'The Garage' started by cannibal, Dec 9, 2003.
  1. cannibal
    cannibal Registered Member
    Mar 13, 2003
    56
    Amman, Jordan
    heya all,
    as the topic says, my brake lights wont turn on when i push my brakes, and coz im alittle ignorante in what deals with electricity, can anyone give me a hint....
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Mine did that too, under the dash the brake pedal pushes a plunger which switches them on, that may need to be adjusted. Thats what solved my problem anyway. /forums/images/graemlins/thumb.gif
  3. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    KISS
    (Keep It Simple Stupid.) Just a saying. Not aimed towards you, just in general. Check the easy stuff first. Like the Fuse. Then bulbs.
  4. cannibal
    Mar 13, 2003
    56
    Amman, Jordan
    ok, dude
    thanx
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    First check your fusebox for a burned fuse. If its burned, then it is shorted, or old. If its shorted, you will keep blowing fuses. If it was just the fuses time to burn out, you will be alright.
    Second, it could be be bad bulbs, but I don't see how both go out at once unless you were near a UFO or one was bad already and a second one burned out.
    Third, it could be your switch. It is above the brake pedal and have a shaft sticking out of it. When you push the brake pedal the shaft falls and lights come on, when you let go the shaft goes back in. You could check for loose or dirty connections there. If you have/can access an ohmmeter you could check the switch for continuity ( it is normally open , when brake applies it closes to complete circuit ).
    These trucks aren't getting any younger. May be a good idea to get a srvice manual with diagrams, as you will need it again, and again over the course of ownership.
  6. cannibal
    Mar 13, 2003
    56
    Amman, Jordan
    yeah, sure,
    thats good man, interisting idea, where can i get the service manual, i mean o the net, from amazon or where
  7. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    check the fuses, brake pedal switch and bulbs.. not common for both bulbs to go at once...
    ebay.com should have some service manuals available..
  8. vince13
    vince13 1/2 ton status
    Dec 6, 2001
    105
    Penticton, BC Canada
    sounds like the brake switch, very simple and cheap to fix, something like 5 bucks for the switch and 2 plug connectors and your done
  9. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    mine did that a couple of years back. I did nothing. They are fine now. Something must have shook right.
  10. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah mine just had dirt in it, so the lights would get stuck off.
