My rebuild thread...."Rising from the trash" (lots 'o pics)
Discussion in 'The Garage' started by big94gmc, Dec 3, 2005.
  1. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    I've got a 14b to replace the one that bent in the rollover. It's already 4.56'd and Detroit'd, thanks to my buddy Scott here in P'cola (he can post up and take credit for his work). The truss for the wishbone of the three link is 2x2 square tube - I think it looks pretty good. It's not done being ground on and smoothed out, but you get the idea.
    I'm doing this in my driveway....not the most ideal work conditions, nor do I have all the equipment that I'd like available, but it works out. As you can tell, I just have alotta crap laying around, and it's getting to be quite a mess. The frame being swapped to is on the left (powertrain already swapped in so I can get driveline angles).
  2. big94gmc
    Sep 1, 2004
    3,651
    No VA.
    Got the 1/4 elliptical welded on, and lower links tabs tacked on the frame....have to hit them more later. 14b is almost ready for paint. Hubs are ready. But I did have a problem with the disc brake brackets I got from GreatLakeOffroad - the bolt holes were the right distance apart for the D44 calipers, but there was too much material in the way for the caliper to fit in....you can see the marker line I made for the area that I had to grind away on one side, the other side I already ground. So, grinding took care of the problem, but I wasn't too happy that these required modification to work. Anyway:
  3. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    looks good., did you use a grinder or a wire brush on the axle? there is so much dirt and grime on mine, i just wanna clean it up.
  4. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,027
    855
    Pinckney, MI
    How much lift is that going to give ya after ther 1/4 eliptical???
  5. big94gmc
    Sep 1, 2004
    3,651
    No VA.
    I used oven cleaner to get the greased knocked down, then the grinding wheel work out the rough stuff, the flap wheel to polish it up, and the wire wheel wherever it was needed, too. Should turn out nicely. I'll be doing the same to the D60, and the 'links.
    I don't know....alot, that's for sure. I'm guessing the springs are cut up Chevy 4" or 6" - most likely cut up 4". I didn't make them, just using them.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    what is your welder? Don't see a whole lot of heat affected zone on the base metal. Do anything special when welding to the cast iron of the housing?
    Looking good so far, and if you need to clean up that truss anymore I need to get my eyes checked :haha:
  7. big94gmc
    Sep 1, 2004
    3,651
    No VA.
    Lincoln 135.... ;) And if you could see the back side of the frame, and the smoke that was coming out of the axle tube, you'd have agreed there was penetration. :D
  8. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    looks sweet :bow: now when u come up here for christmas break you can help me do this to mine :haha: :rolleyes: i wish
  9. big94gmc
    Sep 1, 2004
    3,651
    No VA.
    It's painted....and BLING BLING-ing:haha:
  10. Ten_Bucks
    Ten_Bucks 1/2 ton status Premium Member
    Dec 9, 2004
    892
    46
    Placerville, California
    Lookin' good so far!
  11. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Nice work. :thumb: It looked like a total loss when you started.
  12. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I like the 1/4 el.... :thumb:
    Marv
