My rig feels like its running out of gas when there is still 2 gallons in tank, any ideas?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Nov 30, 2000.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    Well I'm not actually done diagnosing this problem but this is what has happend so far. Gauge reads 1/8 of a tank. Engine idles but bogs and stalls when I punch it. Removed gas cap and there was tremenous suction of air. Refueled, put heat and techron in there and it ran fine until it got to 1/8 again, same problem. Put gas in, and it runs again. This sounds like I ran out of gas but my suburban has a 37 gallon tank and It took only 35 to fill it. My guage has worked fine until now. Could there be a venting problem leading to much vacum in the tank thus causing problems for the fuel pump? Where should I begin to diagnose the fuel gauge? Any other suggestions? A friend of mine had the same problem with his blazer and never figured it out. I have a 1990 350 tbi. Thanks.
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Mine does the same thing. Its probably because of the small amount of gas in the tank, sometimes no gas goes in the fuel line for a small amount of time, and it seems like its running out. The best way to fix this IMHO is to not wait so long to fill it up.
    90K5
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I have an add on EFI set up and it only runs reliably down to about 5-7 gal in a 31 gal tank. Mine is an 82 tank with no baffles. I can watch the fuel pressure gauge and tell just how the tank is sloshing, example, I have to be careful cornering when it's low on fuel because it runs out RIGHT NOW! BUT, it ran fine to almost empty (1-2 gal left) with a carb on it, leading me to believe carbs run on the fuel in the bowls a lot more than we think. A carb can take a minute or more to run out of gas when the fuel pump is turned off, so you go around a corner and lose fuel in the pickup at the tank and never notice it as long as you cover the pickup back up within that minute or so. With EFI, as soon as the pickup is uncovered, they suck air and you're done.
    I'd have to agree on the fix, don't let it get that low.
    SW
    SW-ORD
  4. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Fuel injection requires constant line presure.Example- With a carb, the fuel pump can stop and the engine will run untill the bowl is empty. Fuel injection, the pump stops, the line presure goes away and the engine stops. What is happening with you is, the pump is sucking air, thus lossing line presure. Solution- Gas up at when the gauge says 1/4 and the problem is solved.
    blazen91
    Protect the land FOR the people
    <font color=red>Not FROM the people</font color=red>
  5. Glenn
    Glenn Registered Member
    87
    North Kingstown, RI/USA
    Mine does that to but I have more gas than you in it. When I take sharp turns it starts to buck and quit. This happend after I put a new fuel pump in the tank. I guess I screwed it up somehow and it is to high. My gas guage is broken so thats when I know when it is time to fill it up.:) Works out good for me.
  6. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Um... Gas is only 1.50 a gallon... Put some gas in the tank...
    Um... yes officer I know it's too big...
  7. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    With tbi you should keep tank at least 1/4 full to keep fuel pump sumurged. The fuel keeps the fuel ppump lubricated. Running fuel tank constantly low will shorten fuel pump life. Just my .02 My 89 did the same thing when low on fuel.
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I honestly don't think you have any problems except for the fact that you are running out of gas. Only 2 gallons in a 37 gallon tank is nothing, the fuel level is maybe only an inch deep at that point and the pump just can't get enough fuel. It would probably idle fine because it doesn't need much fuel to do so, but when you punch it you have the combination of needing a lot more fuel plus the small amount of fuel that is left is being sloshed to the back and further depleting what is available for the pump to pick up.
    In other words, just keep more fuel in the tank..........
  9. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Man, Im jelous. My fuel tank is only 24 gallons. Then again, I have a class III hitch in the back. My fuel gauge is messed up to. Says I have a quarter left, when I have like 1 gallon left.
  10. I have always treated my truck as empty when it reached 1/4 tank on the gauge. This has worked for me so far
    '84 K5
    Chevy in my blood.
  11. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    My brother has a Camaro with TPI. He says his fuel pump is huge and holds about a gallon inside. If yours is the same, then that leaves you with very little gas left on the tank. He always has trouble turning when running less than 1/4.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  12. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    If you really wanted to to be able to suck the tank dry, you could get one of those race car pickups for the fuel pump. It is weighted or something and moves the fuel intake hose around in the tank in the same direction that the fuel goes when you corner, brake or accelerate. When you get to the very bottom of the tank, you will usually need to replace your fuel filter afterwards, since you will then suck up a lot of the crud that has layed dormant on the bottom of your tank for a long time.
    However, in tank pumps are cooled by the gasoline, so it is best to not run around too much with the tank real low.
    35 gallons to fill means that the pump was basically uncovered.
    "They tell me that you can make it to work without big tires. I'm still not convinced."
  13. shum1
    Oct 8, 2000
    270
    UTAH
    Thanks everyone for the helpful responses!
  14. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I just watch my odometer and at about 300 mi I fill er up. Since I don't have a fuel guage I have to do it that way...and also since its Diesel I don't think I want to have to deal with an empty fuel system!!!!
    SK-15
    J**P...it's whats for dinner!
    http://SK-15.coloradok5.com
  15. mich89k5
    mich89k5 Registered Member
    Oct 30, 2000
    40
    Michigan
    hey Reddog,
    You're OPECS and the big oil companies dream consumer. You shrug off a 50% increase in price in less than a year. I hope you were kidding. I'll be happy when gas is down to $1.20 and that's still about 20% increase not to mention all the months that they got us for near $2.00. Even if you're rich you can still complain on behalf of the middle working class.
    Mich89K5
  16. shum1
    Oct 8, 2000
    270
    UTAH
    Well, to make matters worse my tripometer dosent work, my odometer does but its kind of a pain writing it down and trying to remember, any suggestions of where I should look for a new spedometer/tripometer?
