My rigs previous owner should be PIMP SLAPPED for ....( fill in the blank)
Discussion in 'The Garage' started by uglychevyZZ4, Apr 15, 2003.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    ok, here is the time to get it all out /forums/images/graemlins/deal.gif What one or even even better, MANY, retarded things did the previous owner do to the rig that they should be PIMP SLAPPED for?
    Weve all seen the WALMART MECHANIC CARNAGE amuck in 4x4 world, so lets share /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif pics are cool too.
    This will be really cool for those own a rig previously owned by another ck5'er /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
    MINE:
    previous looser tried to solder to the printed circuit board and messed up so he covered it with duct tape, and also welded the u-joints in so they would no longer break, and last but not least, welded the case of the old auburn posi where the case had cracked in 1/2, it got me home from buying it, thats it /forums/images/graemlins/rotfl.gif /forums/images/graemlins/1zhelp.gif
  2. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    ok here goes...
    The previous owner:
    1) welded 1" x 3" strips of steel from the trailer hitch to the gas tank... apparently for support.
    2) couldnt figure out how to get the choke to work on the holley carb (manual choke) so he snapped it completely off & took out the choke butterflies
    3) then put on an aluminum spreadbore intake for the squarebore holley and for some reason pinched a piece of aluminum window screen between two carb gaskets - one a squarebore gasket and one a spreadbore - aparently to atomize the fuel better.
    Thats all that I have found so far... but I have only had it a year.
    -Ryan /forums/images/graemlins/k5.gif
  3. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    The carb thing sounds like he bought it from a racer, thats common for them. but the [ QUOTE ]
    [/ QUOTE ] /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gifthats a gene pool thing, right up there with .... umm... eatin possum!
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Re: My rigs previous owner should be PIMP SLAPPED for ....( fill in the bla
    I'm the second owner of my K5. The original owner made add-a-leafs for the front springs by cutting a leaf in half. When I put my lift in, the left front spring pack fell apart when I droped the axle. Made me feel really good about the 500+ miles I drove it home when I bought it. Found more then one tin foil fuce in the fuce panel.
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    How about this gem......???
    The moron apparently couldn't figure out the concept of "big holes, little holes" on a spreadbore Q-Jet....so he installed the gasket backwards!!!!
    It's fun to laugh at the guy.....but then again, I actually BOUGHT the truck from him.... so I'm sure he was laughing too!!! /forums/images/graemlins/grin.gif
  6. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    and it ran?
  7. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    1. For thinking he was mechanic.
    2. For butchering the wiring BEFORE looking to see what was reused to install Painless Performance harness.
    3. For replacing/repairing the front floor pans with real estate signs /forums/images/graemlins/angryfire.gif
    4. For giving his buddy the driveshafts that was supposed to buy the rig and not checking to make sure buddy gave him the right driveshafts back. (I now own a driveshaft for a NP208 when I have a NP203 in the /forums/images/graemlins/k5.gif)
    5. For not knowing what a roll of masking tape is when spraying bed liner in the cab. (all over dash and everywhere else)
    6. For not reading the prep instruction when spraying bed liner. (now all popping off)
    7. Again for thinking he was a mechanic.
    8. For using a crowbar to remove the roof rack. (now leaks through every hole in the top.)
    9. for replacing a rotor after loosing tire and not fixing the backing plate that is mashed in to the rotor.
    10. For cutting up the gauge bezel because he thought he was smart enough to install autometers.
    11. For not knowing that you are supposed to remove the old window tint before installing new.
    12. For being stupid in general!!!!!!!!
    Somebody top that!
  8. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    611 Miles from Salem, OR to my house in San Jose.....
    and a few hundred miles around town too.... I'm not saying it ran WELL...but it ran.
  9. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    [/ QUOTE ] /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  10. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I like the rust fixer from the guy before me. In the way back at the tailgate rust he uesd probably 5 tubes of silicone caulk and just filled all the holes with that and mesh screen. Below the passenger seat he stuck tiny guage sheet metal and glued it in place with some type of undercoating or tar. He then placed a ziplock bag between the carpet and the metal, too um prevent rust from all that interior moisture??? Still finding rust, oh he also told me it was 3.73 gearing, he was slightly off I now have 2.73 gears with 33s.
  11. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    OMG /forums/images/graemlins/eek.gif I thought I was the only one with the real estate signage custom flooring.
    Also the back floor area around the tailgate was pieced together with aluminum step flashing. /forums/images/graemlins/tongue.gif
    John
  12. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    for giving me a free truck with a lot of body rot, what the heck??? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  13. Emmettology 101
    May 9, 2000
    8,126
    FL
    On the 82(Emmett):
    1. Jerryrigged dual tank set-up
    2. Old rear floor rotted so they put repair panels over the rotted floor and just glued them in. It lasted about 6 years of hard abuse...
    3. Cut a hole in the dash for a cheap Radio shack cassette deck and EQ...
  14. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    /forums/images/graemlins/rotfl.gif these all sound so familiar /forums/images/graemlins/rotfl.gif and mine had BLUE shag carpet too /forums/images/graemlins/laugh.gif
  15. CJeepFreak84
    CJeepFreak84 Registered Member
    Jan 13, 2003
    32
    Northern New Jersey
    1.For selling me a 5.7 that turned out to be a 5.0...
    2.For not mentioning the engine bearings were on the way out (JUST KEPT FILLING THE THING WITH OIL TO QUIET THEM DOWN)
    3.Selling the best 4x4 on the planet and keeping his toyota!!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
  16. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    P.O didn't feel that rust repair was that important so he installed brand new carpets to hide the floor rust.
    Block of 2x4 holding the rear window up...told me the switch was broken/forums/images/graemlins/rolleyes.gif
    Installed Rancho front springs.
    All of that was so long ago though...
    Rene
  17. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    Love the silicone rust fix. My PO used masking tape to cover the rusted holes and then spray paint over that.
  18. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    [/ QUOTE ] /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif Thats fawked up, really just wrong /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gifbut funny!
  19. ChevyHuny
    ChevyHuny 1/2 ton status
    Aug 17, 2001
    2,279
    Washington State
    I could say for leaving a towel in the intake and setting the truck a blaze but then I would have never gotten it. However trying to extinquish the flames with large rocks is a good reason for a pimp slapping. I am still finding those things /forums/images/graemlins/mad.gif
  20. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ] Those 2 sound REALLY familiar.
