My Roof's caving in
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76_Cheyenne, Apr 6, 2002.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    My Roof\'s caving in
    The roof liner stuff is coming down from the inside of my roof and its resting on my head. It's annoying and I can't find a way to get it to stick to the roof. I've tried double sided tape, tacks and velcro, to get the linerto stay up. What is used to hold that stuff up? Any ideas?
  2. angelglo
    angelglo 1/2 ton status
    Aug 4, 2000
    105
    S.F. bay area
    Re: My Roof\'s caving in
    use spray adhesive that can be bought at local auto store or hardware store.
  3. lgk5
    lgk5 1/2 ton status
    Apr 3, 2001
    269
    slc,ut.u.s.a
    they sell a spary on glue at auto parts stores ,i can't think of the brand name
  4. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    good luck. The only way I could fix it was to have it recovered
  5. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    I was an upholsterist. The only way to fix it is to take it all out, clean it off, and recover it.
    Ben 87 Jimmy
  6. wheelnut46
    wheelnut46 1/2 ton status
    Nov 27, 2001
    122
    Rhode Island
    Whats a headliner?
  7. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    You want to fix it?!!! Mine was in perfect condition (still is - but now its in the garage!) when I removed it! I like the look of the painted roof vs the fabric stuff... plus have fun getting mud off of it! Just my .02!
    -Dan
  8. 76_Cheyenne
    Jan 23, 2002
    285
    Missoula, Montana
    If I take it off will the the stuff its supposed to stick to come out to?, cause under the headliner is this nasty material that nothing sticks to.
  9. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Mine came out all in one piece... The foamy thingy up there is held in by the trim around the top of the doors, and the back of the cab. You will also have to pull your visors off while removing the headliner. Once its removed, there should just be a nice clean painted roof! /forums/images/icons/wink.gif
    Good luck!
    -Dan
  10. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    183
    Phoenix Arizona
    Pocket knife took care of mine
  11. BlazinRojo
    BlazinRojo 1/2 ton status
    Mar 29, 2001
    111
    San Luis Obisbo, CA
    just pulled it off, wired brushed all the old adhesive off the cardboard backing and brought it down to the upholstry shop to get it redone.
  12. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Had the same problem with mine falling down. I tried the spray glue stuff,but it didn't work. The best fix I found was to take the damn thing out.
  13. dyeager535
    26,980
    You can buy this stuff from some company online. New, the foam is bonded to the headliner, then that is glued to the cardboard. Once the foam breaks down, it's all over...you have to scrape it off, and you can re-glue it, but I bet all the cardboard imperfections show through.
    The other problem is that the vinyl shrinks quite a bit for those trucks so equipped. The shrinking vinyl tears the foam for the same effect, sagging headliner.
    For the life of me I can't remember the name of the company..they sold exact replacement material for the headliner.
  14. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    RIP IT OUT... use the spray ion bed liner... in the can at napa... works killer, just lightly sand where you want it to stick...
    Looks good too.. hurts when you smack your head on it htough...
    hehe
