my s10 wont start
Discussion in 'The Garage' started by 86chevybanshee, Feb 21, 2005.
  1. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    well i went out this morining to move my s10 and it wouldnt start. its a 92 with a 2.8 tbi, the night before it ran great. but when i went to start it this morining it wouldnt start, it would just crank. i sprayed starting fluid down there and still nothing.
    any suggestions?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    did you check the spark
  3. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    yea, its a weak spark
  4. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    replace the coil or check the coil wire. could gave got some moisture in there or something.
  5. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    ok anything else i should check
  6. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    check your pick up coil.
  7. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    i put an accel coil pack my friend gave me and it still wont start
  8. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    did you check your pickup coil? It is under the cap and hooks to the ignition modual which you should also check
  9. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    how can i tell if thats bad?
  10. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    for the pick up coil use a ohm meter and check the restance of the coil it should should be between 500 and 1500. the ignition modual you can have checked at auto zone. you do not have to take the distrubitor out to test either of these. If both of these it could be your computer.
  11. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i would change the ignition module.
    also , are you sure its a 2.8 ?
  12. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    yea positive its a 2.8
