My SAS S10
Discussion in 'The Garage' started by sled_dog, Nov 27, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Said I'd post pictures when it rolled out of the garage, well towed it here to school so it definetally rolled out of the garage.
    Well there it is. Front high pinion Dana 60 is moved 10" forward of the stock "axle centerline". 100.5" now it is 110.5". Will be moving it forward 1.5" more(to help correct the pitman arm to steering arm alignment and approach angle). Rear axle will be pushed back with the 4 link setup. Not certain how much yet. Want to help departure a little but don't care for much more wheelbase. Going to section the front fenders to get a bigger wheel opening and more underhood space.
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Cool man, you gonna move the rear back at all? You're gonna link the back correct?
    BTW, how far is school from home? You left the hubs uncovered the whole way?
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    300 miles. Yes left them uncovered, rained too :doah: Entire front end is getting rebuilt before it sees the trailer. New wheel bearings are sitting in the shop. Everything is so greasy I don't have any worries.
    Yes rear axle is moving back, not sure how much yet.
    I really need to clean up some of the work I did at home. Grind down and build up some welds to make it all look better. Gusset up the front frame extension and mounts.
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    what springs did ya use up front? look like 56's?
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    52s. Going to remove the overload and replace it with a zero rate to move the axle forward without adding height.
    56s would have come back too far under the frame to allow for a shackle. I built it trying hard to keep it as low as possible. Actually ended up lower than I anticipated, will see how it works out.
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    looks kinda funny with full width axles on it. so how much lift total is it gonna have? are the springs in the front the actual hieght its gonna be, or are they just for mockup?
    looks good man :bow:
  7. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    the real question is, where did you find a rust free 80's model s10 in PA?
    that thing looks sharp.
    ryan
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Florida :D
    Dad bought it off of a guy soon after he moved up here when I was 15, technically its my first car :haha:
  9. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Wow, you really moved that axle forward. How far do you think? Have you gotten your steering figured out yet?
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    10" forward.
    Steering, I have an Astro steering box with stock astro pitman arm. Going to see if I can ream it to the proper size. Need to move the axle 1.5" forward yet to line up the pitman arm and steering arm better.
  11. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    What size tires you planning on running on that thing? Even if you were going to use those dinky ones you've got on there just to move it around, I'd think you might as well take the whole front fenders off as much trimming you'd have to do.
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Yeah I know, but my dad wants to see the fenders stretched out, and what he wants is usually best to do because he'll bug me about it forever if I don't at least try it.
    Going with 39.5" IROKs.
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    no offense dude, but i think its time to get off the teat, and tell daddy to pick up some tools if he's gonna be that way. my dad tried that stuff with me with my first truck, and he quickly learned its my money, and my labor going into it. dont like the way its going? contribute something, and maybe you'll have a say in the outcome.
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    my dad does contribute, and I think the extended fenders could look quite good, won't know until I do it. My way is the easy way, but hey the easy way is rarely the right way so I might as well try it. Though getting dad off my back is a big part of it.
    If I really cared what my dad said about it or listened to him when I build things, the truck would either be a circle track dirt car or it would be sitting on 36s and be street driveable, while that would be nice, I like where it is going better.
  15. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Stretching the fenders would be a lot of work for them to end up dented and wrinkled from woods trails.
    Have you considered cutting from the top of the arch of the wheel well straight forward?
  16. Inu-Hanyou1776
    Oct 1, 2005
    1,345
    Murphy, NC
    That's going to be some serious stretching then to center up the tires in the new fenders. You'd be stretching the hood also, as well as the rest of the entire front end too for that matter.
  17. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'm aware. What do you mean the rest of the front end? fenders and hood is all it would be.
    Cutting straight forward from the arch was my idea for it. Especially since there is no parking lights(they were in the front bumper).
    May do that yet, thing is the frame extension would make a great winch mount.
  18. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    sweet s-10
    I need to get mine going again
  19. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Man Alan, nice progress. I cant wait to see your rear link job, mind takin a butt load of pics for me during the process?
  20. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    hmm...fullsizes narrow the front end and midsizes make it wider
