My SM465 is stuck in 1st gear, what do I do?
Discussion in 'The Garage' started by Chris Demartini, Sep 14, 2003.
  1. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">This is the SECOND time this has happened to me, I thought these werent supposed to break? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. bigslok5
    bigslok5 Registered Member
    Sep 9, 2003
    67
    Wheatland, Ca (northern california)
    Take the top cover off. Check the shift forks for wear. I had one that caused it not to shift into gear. Could be the problem.
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Gotta be in reverse to get the cover off
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    push in the clutch,LOL
    sorry I couldn't resist.
    why not crack open the inspection covers?
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    My '77 used to do that if I shifted it too aggressively. /forums/images/graemlins/frown.gif The tip of the shifter gets jammed between the blocks on the shift forks. The fix is pretty easy though!
    1. Remove the shift boot.
    2. Press down on the dome shaped part right where the shifter enters the tranny
    3. While pressing down, turn the domed part counterclockwise 1/4-turn.
    4. The shifter should now lift right up out of the tranny.
    5. Using a LONG screwdriver, move the shift blocks so that the notches in them line up to form a square. This should be neutral.
    6. Insert shifter. The tip should fit into the square formed in previous step.
    7. Press down on dome shaped part and rotate clockwise 1/4-turn.
    8. Reinstall shift boot.
    /forums/images/graemlins/thumb.gif
  6. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    try having someone rock the truck while pulling it out of gear? just a thought...
  7. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">The forks were misaligned, its fixed now. I also welded the roll pin into the shifter, it doesnt have as much play now
