my smogable rochester carb bit leaks like mad, who can fix it?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mike83blazer, Dec 18, 2002.
  1. mike83blazer
    mike83blazer Registered Member
    Nov 16, 2002
    90
    Southern California
    I have a 2 original smogable rochester carbs circa 1980 or so. they both leak very bad. I am forced to use my 750cfm holley, unfortunataly this is not a smogable option in the good state of california. I need recomendation on where to have one of these rebuilt or where i can buy a new one(cheap)
    /forums/images/graemlins/1zhelp.gifMike Pless
  2. dyeager535
    26,978
    Leak? Where from? If its the carb inlet, believe there are some repair options for that, maybe even at a chain auto store. If it's leaky gaskets, $15 "rebuild" kit and an hour or so and you should be back in business.
  3. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    If they are leaking from the two small plugs on the bottom near the throttle plates, JB Weld them...worked on my old '82.
    I think Checker has actual Rochester carbs for 2 bills or so...
    /forums/images/graemlins/burb.gif
  4. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    My old Rochester leaked like really bad too. After I threw it away (no smog /forums/images/graemlins/laugh.gif ), I realized that my new mechanical fuel pump was creating too much pressure and made my new Edelbrock carb flood too. Apparently neither carbs' float bowls could stop the pressure from the mechanical fuel pump.
    Hence, I added a fuel pressure regulator - the cheap in-line kind, IIRC $9.98. It was chrome, has a big dial on it and reads from 6 to 1 in one pound increments. I left it on 6 on the street and brought it down to 2 when I went off-road.
    Good luck.
  5. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
  6. mike83blazer
    Nov 16, 2002
    90
    Southern California
    that new part from my auto store fixed that problem. thanks
  7. mike83blazer
    Nov 16, 2002
    90
    Southern California
    were did you get that?
