my steering box is leaking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Jan 14, 2003.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    after I went wheeling last time i noticed a new oil spot on the ground, my power steering box is leaking from the back where the steering shaft bolts up. Is there any way that i can fix this or do i need to get a new box? If i need a new one, what years will work with my 73? /forums/images/graemlins/confused.gif
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    You can buy a rebuild kit,but if it was me I would just buy a brand new steering pump.
  3. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    its not the pump thats leaking, its the actual steering gear box
  4. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    let the thing leak til it gunks up so bad on the outside it stops leaking. /forums/images/graemlins/grin.gif mines been leaking for years and i just keep adding fluid. /forums/images/graemlins/frown.gif
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    ..... /forums/images/graemlins/rotfl.gif
    ANd he's worried about a few drops...
    Well I never had a blazer with a clean steering box. As soon as you start working it it will start leaking. Mine looks pretty bad but every couple of months I check the level and it's a little low so I add some.
    When I feel that it's getting low in less than a couple of weeks then I would think of replacing it.
    Now if you don't intend to work it hard on rocks or mud and you want a clean driveway then go ahead and replace it, it's cheaper.
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    You can replace the seal pretty easily i hear...i replaced my whole box because it was fubar'ed bad though, it also leaked all over my draglink ends and probably messed them up too
  7. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    Pull the steering shaft off and start it again. Check to see if it's leaking from around the input shaft or out the end of the shaft its self. If the shaft is leaking then just go get another box. If it's just the seal then you can get them cheap at a local parts store or i'll be more than happy to send you one.
  8. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    yeah, the fluid lever gets low pretty quick. ill have to look tomorrow to see where exaclty the leak is from but I was wondering what years would have a direct swap, as far as thread sizes on the hoses are concerned?
  9. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    i just replaced the new steering pump box, and both lines./.. 60 for pump w/resivoir, 20 each for the lines...
    5 for fluid...
    doesnt leak a drop... /forums/images/graemlins/thumb.gif
  10. reddog64
    Nov 9, 2000
    3,325
    nevermind.. i read some more...
    A new gear box is 50 at the wrecking yard...
    or send it to the guy that does hydropic assist steering and he can rebuild it cheaply! /forums/images/graemlins/thumb.gif
  11. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    if its the seal around the input shaft its not hard to change just drill the breakaway pins in the colom then remove the boltat the base below the doughnut the hard part is getting the shaft to collapse i always use a pipewrench on the lower side then beat it back with a three pound mall once you get it off there is an outer sael and then a snap ring then an inner seal then just put it back together if the knockout pins go all the way through then you can replace then with plastic dowls
