my steering has a mind of its own...wtf
Discussion in 'The Garage' started by muddybuddy, Apr 20, 2006.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    welli installed my hydro assist, and i had the k5 running and the front jacked up and i was turning the tires lock to lock to bleed it. once it got really easy that way, i sat in the truck and tried to steer it. when i turn the steering wheel, it seems to have slack and jus jerks instead of being smooth like it was before the ram. also, when i turn the wheel either way, the tires want to turn left...i dont get it. does it matter which line goes to which fitting on the ram? here are some pics of my lines, sorry for the poor quality, its dark out now. i have the line from the end cap on the box going to the left fitting on the ram, and the line from the top cap to the right fitting on the ram. any chance i ahve them backwards, or does that not matter?
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    i think somebody crossed the hoses... :whistle:
  3. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    alright, was there any way to tell before putting them on, or is it jus trial and error? well ill switch hoses and hopefully that solves the problem :)
  4. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Sounds that way ;) :haha:
  5. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    just take one of the clevis bolts out on one side of the ram then turn and see if it goes the right way
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah, sounds like hoses crossed to me. But as a side note....can't help noticing that it looks like your U bolts aren't tightened down. Also looks like they're not sitting on very much. Is this just a trick of the picture?
  7. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    good eye
  8. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    its just the lighting, everything is down tight.
    i switched the lines, everything works perfect! tonight was the first time i have driven it in 7months! granted it was only around the neighborhood, its still awesome. im so excited! :)
  9. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hmm i didnt think of that. yea its a 5* shim. i wish i had a 5* tapered zero-rate instead. this summer i will be swapping to 52s upfront, so the zero-rates/shim combo will be going away. i appreciate the concern, its wat makes this site rock :saweet:
  10. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    For my rear axle I've just made a 1 1/2" zero rate then milled a 6* slope on it. I ended up with the right ride height and proper pinion angle. I only went that route because I couldn't source a degree shim over here but it worked out pretty cool!:D
