My steering is driving me insane.
Discussion in 'The Garage' started by k5freak44, Dec 3, 2005.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    Well now that i finally got rid of the Death Wobble, i have a completely new steering setup from the pitman arm to the tierod (i replaced everything that could wear including balljoints).
    i think i did an ok job of aligning it but i need to know if that is my probelm....
    when im driving i have to cock the steering wheel to the side about 1/8 of a rotatoin, if i let go it jerks to the right and the steeringwheel centers.
    what could this be?
    im not sure if its toe or not but what else could it be???
  2. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    oh and also, i noticed my turning radius to the left sucks now, i think that might have something to do with it
  3. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    Sounds to me like your draglink needs adjusting in length, i.e. alignment.
    -- A
  4. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    but last week it was fine.
    what could have messed it up so bad???
    i have been 4 wheeling sense :D
  5. dremu
    Feb 27, 2000
    15,967
    459
    Um, steering box could be cocked on the frame or the frame could be cracked... rag joint could be whacked ... or you could have miscounted turns on the draglink and/or not tightened it enough.
    -- A
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    re-adjust ur draglink, thats why ur left turning radius sucks. get ur x-over already :wink1:
  7. KTEX
    KTEX Registered Member
    Nov 8, 2005
    19
    wylie
    The pulling to the right could be a tire pull,caster or camber pull-camber pulls to the more postive side.there is a a shim on the upper ball joint that unscrews from the knuckle,you could have out of adjustment-need to have the alignment checked-they have aftermarket shims.or the gearbox could cause a pull.I have been a front end tech for 15 years-most pulls are tire related-try switching the tires around and see what happens.
  8. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    alright. my tires are NOT balaced by any means so ill see if moving them around makes a diffrecne
