my steering is making knockin noises?
Discussion in 'The Garage' started by 87sm465np208, Nov 4, 2002.
  1. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    why is my steering making a poping clunking noise once in a while? when i steer left or right, it makes me think when im drivin and i just want to know what it is, if anyone can help id really like it /forums/images/graemlins/grin.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    99% chance that the frame is cracked at the steering box. /forums/images/graemlins/shocked.gif That's a VERY common failure on these rigs. /forums/images/graemlins/angryfire.gif
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    How loud is the clunk? Is it more felt through the steering wheel than heard? If that's the case, I might suggest worn draglink ends/steering box insides/steering shaft.
    Just throwing out some ideas.
  4. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    dang it, well if it is cracked, how do you fix it?
  5. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    it also could be that your axle is shifting forward and back because of a Sheared Center pin in your leaf spring, As for the frame crack buy the Frame repair kit.... Im sure all offroad shops can order you one if they dont carry it instock, then have a friend weld it on there....
  6. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    Try tighting the spring's down some times they will loosen up and every time you turn it will make a poping noise.
    Mine front springs do that about once a month so I got new nylon lock nuts and doubled them up and have not heard the poping noise anymore. Then last monday after elk hunting I was hearing the same noise and the spring bolts were tight. So on my lunch break I was driving down the road and I was going to turn right put the truck went strait into a fence. I got out and the draglink end had busted of. So just check all of your spring bolts and tie rod ends and make shure they have plenty of grease.
    Colin
  7. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    dang, yea im gunna check the u-bolts, they are 150 ft\pounds, thats more then the torque wrench goes up to, lol, but yea ill check them, see whats up with it. and could you feel the pop in the floor by your feet?
  8. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    since your down there, id check them center pins too.....
  9. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    ill look at it tomarow
  10. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    im probly gunna say its the u-bolts too, because of the fact that i bounce that thing over rail road tracks over here, really hard, and i see my leaf springs shift occastionaly, in front side to side, oh well if im feelin up to it, which i am, ill go take a long pipe and a socket and my 1\2 ratchet, im gunna go do that.
