my th350 shifts weird.
Discussion in 'The Garage' started by the excuse, May 28, 2004.
  1. the excuse
    the excuse 1/2 ton status
    Dec 9, 2003
    209
    san diego
    i installed a trans cooler so now my 350 runs about 100 degrees when on the freeway. when ever i first start it my tranny acts like it is in neutral when i shift into reverse or first. for example ill start my car put it in drive and the engine will just rev, then it will catch like a second later and go into drive. whats the deal? in reverse it is the same. once it is started it will shift like normal.
  2. hatchetjack
    hatchetjack Registered Member
    Feb 13, 2004
    28
    LA (lower Alabama)
    Did you add fluid to make up for that lost in the extra space?
  3. the excuse
    Dec 9, 2003
    209
    san diego
    the fluid i inbetween the low and full marks. the tranny should be hot when checking the fluid right?
  4. gm guy
    gm guy 1/2 ton status
    May 1, 2004
    151
    Vancouver Island but work in Ft Mcmurray Alberta C
    Yes hot and in nuetrel (sp). Oh and block the wheels!
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    sounds just like your low on fluid /forums/images/graemlins/yikes.gif some people don't know you have to have the motor running and in park or neutral when checking the tranny fluid
