My tie rod ends might as well be welded on
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5blazerus, May 7, 2003.
  1. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    Try using the bottle jack under the tie rod bolt and hit the side of the knuckle a few times BF HAMMER
  2. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    I've had luck with hittting the outside of the knuckle with a hammer. OR go rent a pitman arm puller from Autozone or buy one for $20. You can use this to all of the drag/tie/pitmans on our trucks.
    Blake
  3. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I already tried that once. Had most of the weight on the jack, hit everything with a little hammer, then a big hammer. Nothing happened. I've been trying to get this tie rod off forever.
    Last summer I made my first attempt. I even took the nuts off completely and took it up backroads driving around over all kinds of bumps. It never did come loose. Put it back together, and I've hardly driven it since. I tried a month ago, but no change. Still stuck on there.
    But I'm afraid to drive the thing... and I'm supposed to tow my trailer 85 miles with it on Friday.
  4. mountainexplorer
    Nov 14, 2001
    4,903
    They wont come off. It's a tie rod on a Dana 60 front on my '81 Crew Cab. The ends are worn horribly, but I can't get the ends off to replace it.
    I've tried spraying them with WD 40 and other stuff, tried a pickle fork, used many hammers, and even a bottle jack that lifted the front tire off the ground but still didnt push the tie rod end out of the hole in the knuckle.
    Is buying a special puller the only way?
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Try a little heat. then hit the side of the knuckle with a hammer.
  6. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Soak liberally with PB Blaster. Rust is getting the better of you right now. Heat will definitely help. Heat the knuckle up and try again with a pickle fork.
    Otherwise the jack method while hitting the knuckle right where the rod end goes through should be the best option.
    Persistence will pay off on this. Once you do get it off, then clean out all the rust.
