my tools are HEAVY
Discussion in 'The Garage' started by ducttape114, Sep 28, 2003.
  1. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    so i got to paking all my tools in my new box geting ready for BB. i packed lightly, as this is the box that rides in my truck and i keep the big tools at camp. i have the bare essentials and the damn box weighs an easy 400lbs. and thats without my socket set, hi-lift, and shovle. wow, i need to get some aluminium tools or somthing /forums/images/graemlins/grin.gif
  2. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I hear ya I went to the salvage yard yesterday with my wrenches, 3/8" and 1/2" drive sockets in standard and metric, and a couple screwdrivers and the damn box prolly weights 50 pounds. Carrying that through the yard was a lesson in pain and I still needed a tool I didn't have as for some reason the truck I was dissecting used torx screws to hold in the lenses /forums/images/graemlins/mad.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The local pick-n-pull has wheelbarrows for you to haul your tools and parts around the yard in. /forums/images/graemlins/thumb.gif Makes it WAY easier than lugging everything around. I've also used a 2-wheel dolly to haul my tools and stuff around in a yard. /forums/images/graemlins/cool.gif
  4. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    I did free lance auto repair this summer, and I had all my tools in two boxes (one box for all sockets and drives, one for screwdrivers, pliers, hammer etc.). They must weigh atleast 35 lbs each. I hurt my back lifting them into my trunk, I was down for a week /forums/images/graemlins/frown.gif.
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I also off road a 'glass dune buggy. You don't carry anything more than absolutely necessary in one of them. What I did was start with an empty tool box. Then I worked on it at home out of that box only. Everytime I needed a tool not in the carry box I got it and put it in the carry box. That way I wasn't guessing as to exactly what I would need or not need.
    One of my former employers had some tools out of the box that a 20's era Indy car riding mechanic had on the racecar. Each wrench had been carefully hand ground to reduce as much weight as possible.
  6. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    When I started whelin I used to cary around all my tools and it took tons of space and weght. I have since brought down to just stuff <font color="red"> I </font> really need. I keep my sockets, some pry bars, and big wrenches for the bigger bolts. A small grinder, a small strong impact and other misc stuff. My big Tap/die set. A misc box with misc bolts nuts. A misc box with electrical stuff.
    CRAP!!! I have lots of stuff!!!!! [​IMG]
    I do not have it all on one box so it isn't CRAZY hevay!!
    I also found over the years there was lots of stuff I never touched so it stays back. LAST!!
    I never wheel alone and my crew and I always work out who has what. We teamcary. The last trip I carried all the spare parts and hardly any tools. Phil had tools, doug recovery. That sort of thing.
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Dude, don't talk to me about weight. I use my toolbox in the back of my truggy to counter ballance the *engine*. /forums/images/graemlins/laugh.gif
    Oh, and I love your jpg generator in your sig. Pretty cool trick...
  8. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Get creative with it.
    For "in-the-truck-tool-kit", it doesn't have to be top of the line, built to last type of tools. It just has to get the job done, once.
    Make your own specialty sockets out of pipe or tubeing. Weighs much less than the store bought socket - and works well enough to do the job - in the field.
    In my lil' part of the world, I regularly work on "odd-balls" (I.E. - something other than G.M.) and have, over the years, collected quite a number of home-made tools and sockets. Built multiple sockets out of various sizes of exhaust pipe tubeing. Most of them are double-sided (two sockets in one) and weight no-more than a 6" piece of tubeing.
    Other sockets/ratchets:
    Ditch the over-lapping sockets. A complete set of 3/8ths sockets, and whatever you know you might need that isn't covered in the 3/8s set. Two addapters (3/8ths to 1/2 and 3/8ths to 1/4). Three lengths of 3/8s extensions. A good, long handled, swivel head 3/8ths ratchet. A short handled 3/8ths "nut-runner". A 1/2 breaker-bar.
    That should cover just about 90% of anything you will need "in-the field" - as far a sockets/ratchets go.
    Some other ideas:
    Double sided open-end wrenches, insted of a complete set of box-end wrenches.
    Modify the high-lift jack handle to axcept a 1/2 socket.
    Stander-ize your truck before hand. Convert, as much as is resonable, to standered sizes.
    Forget about being comfortable, focus on getting the job done.
  9. ducttape114
    Aug 1, 2002
    990
    Orcutt Ca
    i do have a full set of combo wrenches, that might be over kill. everything else is stuff i NEED.
    straps &amp; shakles
    jumper cables
    extra fluids-oil,tranny,t-case.
    come-a-long
    u-joint press
    breaker bar
    tourque wrench, this i could leave at camp i guess
    hand tools-vise grips, channle locks, 3 screw drivers, socket set, etc.
    thats pretty much it. i cant even belive how fast it adds up
