My tranny is cold!!!
Discussion in 'The Garage' started by sickquad, Oct 3, 2004.
  1. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    My 700R4 was running a little warm so I added a tranny cooler and a deep aluminum pan. Now the thing is running just under 150*. Is that too cold for a tranny. It shifts fine and torque convertor is locking and unlocking like it should.
    It's about 65* here now, so in the winter this thing is going to be real cold. Anybody know about this?
    -Chris
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Well, if you want to keep it warmer in the winter, couldn't you just put and inline valve in the tranny cooler line? You could shut it off completely, or halfway, or fine tune it if you want. It's just a thought. I don't know if there is such a thing as too cold, but if there is, that would probably correct it.
  3. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    You can get a thermal valve from Jegs or Summit. It will bypass the cooler until the trans reaches normal operating temp. A good thing to install anytime you add an auxillary cooler.
  4. sickquad
    Jul 23, 2003
    785
    Ma
    I'm not sure if it is bad that it is running cold, that is my main question. Maybe there is an ideal temperature range since shifting is based on pressures and low temperatures are lower pressures?
    -Chris
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I think 150* is alright. If it seems to cold in the winter, just cover the cooler front with something....
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The trans needs to get hot enough to keep water from condencing in it. They should run around 180F just like your motor.
    Take a look at these
    http://www.batinc.net/thermos.htm
    Did you get a stacked plate or a tube & fin?
    The stacked plate ones are suposed to have a by-pass built in for cold weather?
  7. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Here's a good link on tranny temps.
    Looks like 175* might be the minimum.
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    did you keep the radiator cooler inline? i feel for the winter you need to have this and plumbed after the aftermarket cooler.
    the aftermarket cooler will keep the fluid cool and the radiator cooler will get it back up to temperature that it needs to be. this is how mine is plumbed.
  9. sickquad
    Jul 23, 2003
    785
    Ma
    Gotta deal with this soon, it was just over 100* this morning for a while on the way to work. I have it going through my radiator then the cooler. Maybe I'll turn that around for the cold months.
    Good info, thanks guys.
    -Chris
  10. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Maybe it would be nice to have it always run thru the cooler in the radiator and use the t-stat I posted above make it not use the aux. cooler till the temps come up. Would be like not having the aux. cooler hooked up at all during the winter.
    Or you could always move to someplace with a warmer climate /forums/images/graemlins/whistling.gif /forums/images/graemlins/screwy.gif
