my trans has no park?
Discussion in 'The Garage' started by d coenen, Nov 10, 2005.
  1. d coenen
    d coenen Registered Member
    Jan 21, 2005
    76
    bonesteel s.d.
    installed trans yesterday and it has no park all the other gears work but go to put it in park and nothing there? adjusted the shifter and still nothing . is it some thing simple or did he sell me a bad trans.
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    probably some rocket scientist thought that the parking gear was a means of stopping at 10 mph... (The PO's of my burb did).......... I had the tranny guy fix a leak, so I got him to fix the parking problem while he was at it.... its called the parking pawl or pin IIRC.... I don't think it is very hard to replace...
  3. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    If you take the pan off it's hooked right to the shift arm (inside). It's not real hard to replace.
  4. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Yep probably the parking pawl, I had one repaired for hmmmmmm I believe it was around 400-600 with other transmission work.
  5. d coenen
    Jan 21, 2005
    76
    bonesteel s.d.
    what do il ook for when i take the pan off? i dont know anything about transmissions.
  6. d coenen
    Jan 21, 2005
    76
    bonesteel s.d.
    or could it be something to do with my transfercase?
  7. d coenen
    Jan 21, 2005
    76
    bonesteel s.d.
    anyone have any ideas?
  8. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Did you not read the replies above?
  9. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    it's almost definately your parking pawl. if you take your tranny pan off, let all the juice run empty, it will be on the drivers side of the tranny, up against the case, towards the back of the tranny. there will be a long rod that pushes a peice of steel into the rotating drum of the tranny, making it stop. somewhere something will be broken along these lines.. maybe someone else can be more specific or find you a picture, but im pretty sure up to this point..
  10. d coenen
    Jan 21, 2005
    76
    bonesteel s.d.
    thanks im trying to do all the working on my truck myself cause money is tight ill tear into it tonight. thanks
  11. GRAYTEXK5
    GRAYTEXK5 1/2 ton status
    Jul 23, 2002
    281
    Ft. Worth, TX
    I have the exact same problem with my th400. the end of the rod that holds the parking pawl in place was broken in half. so I replaced it, but it still didn't fix the problem. I asked the guy at a local tranny shop, and he said that sometimes the plate that hold that rod in sometimes gets worn down, and that can cause it to not push the pawl far enough, and not hold in park. so I got one from him, and I'm gonna replace it this weekend, see if that fixes it. but if you're gonna tear into yours, you might wanna go ahead and replace that too, while you're already there, just to be safe.
  12. don miller
    don miller Newbie
    Mar 13, 2005
    nashville tn
    The rod could have a broken spring which would not allow it to engage the parking pawl fully. The rod w/ spring should run $5-$10.
  13. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Look in the tech articles forum, at the shift kit install thread. Has a buncha pics, and IIRC says something about the parking pawl.
