my truck farts
Discussion in 'The Garage' started by colbystephens, Apr 24, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    so when i press on the accelorator pedal from any time when i have left my foot off of the pedal, my truck makes a rather fart-like noise from the front passenger side of the truck. this is only for low speeds, however. i had muddytazz take a listen and he noticed it sounded like it was coming from my d44, suggested perhaps i needed to tighten my wheel bearing bolts. just looking for other ideas as well. i attempted to do try his suggestion the other day, but didn't realize i would need snap-ring pliers and had to put it off for another day. if it makes a difference, this happens both in 2 and 4 wheel drive, hubs unlocked or locked in. any thoughts?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If your truck farts, feed it some bean-o man :haha:
    Check those bearings out, cause I sounded like it was coming from that wheel.
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Yeh, Id check the bearings.
    Just fyi, you dont need snap ring pliers, regular set of pliers will get it off, and a little bit of pressure with your hand, and maybe the pliers, will get it back on. Now the outer snap ring, its a pain, my best luck has been with 2 little teeny tiny screwdrivers, one, that I put a 90* bend on the very tip, to hook the ring, and the other to keep it from spinning round and around
  4. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    cool. i think i'll just pick up the pliers tho. trying to deal w/ snap rings and needle nose or small drivers pisses me off like crazy. :)
