my truck wont idle, why?
Discussion in 'The Garage' started by bigoltrux77, Jan 23, 2003.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    My truck had been running great for 4 weeks then one saturday a few weeks ago i started my truck and it wouldnt idle worth crap. I had to keep the brake on and give it gas at stop lights. I finally turned the idle up high enough to idle. What could be my problem? I dont think its timing because timing dosent just get off all of a sudden. My coil and module are new. My plugs and wires are fine. I think it could be fuel. The pump is fine i know that. Any suggestions?
  2. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    check your fuel filter, my friends clogged one day and it wouldnt start nicely or idle, but that is a 91 k5 with a tbi, check it out anyway /forums/images/graemlins/thumb.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  3. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Look for a Vacuume leak.
    Eric
  4. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    Is your choke or float stuck? Make sure all vacuum lines are not cracked or pull loose anywhere. Make sure nothing is stuck in a fuel line somewhere or a fuel line that has busted. Good luck.
