My truck's RTI score
Discussion in 'The Garage' started by 72THING, Nov 13, 2002.
  1. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    My truck\'s RTI score
    I've always been curious about the THINGs RTI score, so today I got my dad to lift the rear tire with the forks on a front end loader. It got 40" off the ground before the other rear tire started to lift up. This calculated to a 936 on a 20* ramp and 640 on a 30* ramp. I was really excited that it flexed pretty good. /forums/images/graemlins/thumb.gif This is on a long box truck with 125" wheelbase. Not too shabby for an old mud truck.
    Will
  2. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Re: My truck\'s RTI score
    Sweet. Did you have a camera?
    We need pictures!! /forums/images/graemlins/thumb.gif
  3. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    ok newbie question what is an RTI score and how do you calculate it ( i do know what flex is you smartalecks) /forums/images/graemlins/confused.gif
  4. 72THING
    Nov 26, 2001
    501
    Ranburne, AL
    I made pics with a regular old camera, but I have no way to post them cause I don't have a scanner. I really need to buy a digital camera, but I spent all my money on the truck /forums/images/graemlins/rolleyes.gif Sorry. But I'd absolutely LOVE to share some of my pics with ya'll.
    Will
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    RTI - Ramp Travel Index...drive one tire up an inclined ramp until one of your other tires stops making contact with the ground. At that point, the distance up the ramp your tire makes it is measured. Wheelbase comes into play, as well as the angle of the ramp.
    Well...here's a more complete explanation:
    some link to another page explaning RTI ramps
    And here's a pic:
  6. 72THING
    Nov 26, 2001
    501
    Ranburne, AL
    I'm not sure how to explain it very well, oh well, here it goes. Its basically a calculation of how well your suspension flexes. RTI stands for Ramp Travel Index. Its simply a ramp set at a certain angle (usually 20 or 30 degrees) that you drive one of your tires up on until another tire starts to come up off the ground. Then the distance is measured on how far you traveled up the ramp. This measurement, combined with the ramp angle and your vehicle's wheelbase is somehow conglomerated into an RTI score. Since I didn't have access to an RTI ramp, I lifted one tire vertically until another tire started to come off the ground and measured this vertical distance. I'm not sure how to calculate it, so I went to www.mark.legendz.com/ramp.html and entered my data and it automatically calculated it. Hope this helps and maybe some body else can explain it better.
    Will
  7. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    alright thanks guys, i am much enlightened (bet my truck would get the lowest possible score!)
  8. Grim-Reaper
    7,385
    Atlanta
    Stock K5 with the sway off will do close to 600 on a 20. That's better than ANY stock jeep with the sway off /forums/images/graemlins/smile.gif
  9. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    Will, nice score. What rear suspension are you running?
  10. 72THING
    Nov 26, 2001
    501
    Ranburne, AL
    Grimmy, a K5 is better in EVERY SINGLE ASPECT than a Heep, except for the width. /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
    Will
  11. 72THING
    Nov 26, 2001
    501
    Ranburne, AL
    Thanks, Marc, I appreciate the positive comments. My rear suspension is actually a conglomeration of things. My truck was originally 2WD, so it had trailing arms w/coil springs out back. When my dad and I put leaf springs on the rear, we used 2WD spring hangers for the front part of the rear leaf springs. This doesn't give near as much lift to start with as 4WD spring hangers. (We didn't know this at the time) So to compensate for my front 6" lift springs, my rear has 6" Tuff Country EZ-Rides with an ORD shackle flip AND a 2" block. Those TC springs flex really good and the ORD flip gives it plenty of free-range-of-motion for the shackles. Now I just need to get rid of those crappy Pro Comp springs up front and put Tuff Countrys up there, then I'll get good flex in front AND get rid of the back-breaking ride /forums/images/graemlins/rolleyes.gif
    Will
  12. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    And except for weight.
    Ken H.
  13. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    I saw a truck that converted to that trailing arm setup in the rear. Pretty cool, I think he was using front F150 springs or something. I've been toying with that idea for some time now, HMMMMMMMMMM /forums/images/graemlins/thumb.gif
  14. 72THING
    Nov 26, 2001
    501
    Ranburne, AL
    If I had to do it over again, I would have left the factory setup in the rear, put the axle under the trailing arms (factory its on top of them) and then dropped the upper coil holders down some if needed to achieve the desired lift to match the front. Then I would fab up an extended panhard rod to compensate for the lift and weld the new mount on top of the rear chunk for it to mount to. This would probably flex like crazy, plus have no axlewrap to speak of. Oh well, hindsight is 20/20 /forums/images/graemlins/rolleyes.gif
    Will
  15. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    we got the wheel base grim, account for that. im not trying to stick up for heeps, but thats is why.
    but our wheel base gives us much more than just a betterRTI score over a jeep... thats why i own 2 k5's
    Grant
