MY TURN..........
Discussion in 'The Garage' started by jakeslim, Dec 31, 2002.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    To #@$%^ gripe!
    Ok, I have worked on my distributor for two weeks. You may have read my post about the bad Mallory(new) and then I had trouble with the replacement MSD distributor. NOW...the $% stupid Heater core is busted. DOES IT EVER END. Well you might say that this is minor? Well it is, BUT............I decided to bypass the heater core(leakiing) by disconnecting and running from radiator directly to manifold. WELL....when I started the k5, it started just fine because the two weekends of work I put into distributor problems was resolved. I always check the exhaust when I work on cars because it is kind of a thermometer for how the engine is running. I noticed that it was a bit white from both sides(dual exhaust). I shut her down and check the oil dipstick. YES, COOLANT IN OIL. It is dark, getting colder and I don't need this. I drained oil(AND COOLANT) from engjne, tightened manifold(hoping that it was just loose and filled with fresh oil. Started back up for a couple of minutes. Drained oil and filter again. NOW I SIT HERE. I obviously need to replace intake manifold gaskets and reseal. DOES IT EVER END.
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I would really like to give you some hope but I would be lying to you. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    And this comes from a man that had to replace his transfer case then his tranny and now I'm having to replace my rearend. /forums/images/graemlins/angryfire.gif
    Eric
  3. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    this k5 stuff is truly a love/hate relationship....and costly.
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I have yet to get the intake on my crewcab to seal worth a damn. The intake's been swapped out twice (thinking maybe they get porous) and the whole engine's been re-gasketed, so a total of three intake gaskets - and it still leaks.
    At least its to the outside, and not into the engine /forums/images/graemlins/wink.gif
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    It's called "Tough Love"......
    A 25-year old truck is going to have problems, and unfortunately you just have to "spend your way" through it.
    I'm doing the same thing on my 31 yr old K5....so I know the feeling.
    /forums/images/graemlins/frown.gif
