my very own 3/4 ton conversion thread
Discussion in 'The Garage' started by makovai, Oct 5, 2006.
  1. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    I've been chattin with alot of you about my conversion but since i have a few pics thought I'd start my own so i can talk about all the mistakes I've made so far.:D
    I traded for this 1974 3/4 ton p/u running gear with 35" BFG's for my superblackhawk.
    Found out there were more expenses than i thought so i sold the 36x14.5 swamper i had on my rig.
    Restored the D44 so it was nice and pretty, but still needed wheels and tires.
    I then traded a warn winch for these 39x18 mickeys.
    Now she's ready to go under the rig, with a cross steer conversion.
    Kinda have some of it under now but there's going to be a flare issue
  2. raymos
    raymos Who?
    Jul 6, 2006
    479
    8
    NOR CAL
    looks bad! keep up the good work and make sure to post more pics.
  3. xpndbl3
    xpndbl3 1/2 ton status
    Jul 30, 2005
    510
    orland park, IL
    looks sweet man....good work so far
  4. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Looks good! What steering box did you use for the crossover? Are you using the 1st gen style ps pump?
  5. makovai
    Jun 6, 2006
    854
    oregon city
    My pictures are kinda weird. I'm showing the front tires on the rig, but it doesn't have the new D44 in that pic. I just put the 8 lug spindles on to see if i had enough clearance. The D44 is still in my garage. So therefore i have not hooked the steering up yet.
    So far it looks like I'm gonna use a PS box from a 1974 2wd suburban. (The gear puller, pickle forks, and big sockets are in my truck now) The the pitman arm will come from a Ford p/u. I haven't quite figured out the year yet because the ones i saw at the wrecking yard just look to whimpy for my taste. my 1 hour for lunch isn't quite giving me enough time to get this figured out. I should be able to get all my parts this weekend.
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    that axle looks very perdy! what did you paint it with?
  7. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    lookin good
  8. makovai
    Jun 6, 2006
    854
    oregon city
    As much as i hate to admit it. I just rattle-canned it. I bought a quart of rustolium paint that i was gonna stick in my gun and shoot it, but i get tired of all the cleanup, so i just rattle-canned it. I'll shoot the rear with the gun though.
  9. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    You're almost so cool! Your light covers in your avatar picture look pink from here - coincidence?
  10. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    looks great :waytogo:
  11. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    Use a van pitman arm - 78 or 79 year. Has tons of meat on the end for reaming to fit one ton TRE or DLE. Otherwise, nice looking truck, my man! :bow:
  12. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Have you ever run those Mickey's? I love my Baja Claws, and the fact that they are 16" wide, your 18" wide tires are going to be great!
    Do you get onto the sand much or were they just available?
    -Avery
  13. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    18" wide and d44....watch out.
    that axle looks much better than being just rattle canned. with my axles, i didnt even prep them, i just sprayed the duplicolor bedliner on them and ive been happy with them. wish i had taken the time to prep them correctly.maybe later.
  14. wow! Great job, looks awesome! :waytogo:
  15. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Prep is the key. there is no reason in the world that a spray can cant do a very, very, good job. especially on something like an axle where there are no wide open areas to cover.
  16. makovai
    Jun 6, 2006
    854
    oregon city
    Mine are primered and sanded and even clear coated, But unfortunaley rattlecan only looks good for a few months, then it fades. I hope the clear coat holds the shine.
  17. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    It all depends on what type of paint you get...I picked up some paint at Auto Zone to spray my axles/truss/fender wells/etc. and it is still just as shiny as when I put it on about 5 months ago.
    -Avery
  18. makovai
    Jun 6, 2006
    854
    oregon city
    finally, somthing to update this thread. The front is pretty much done. I need to bleed the brakes and put the grill back on. The cross steer is complete, except i am thinking really hard about the borgeson universal steering now. It turns out the new 2 wheel drive box uses a smaller rag joint connection, so i may just replace the whole bar.
  19. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    looks purdy!
  20. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    nice thread. that is a nice truck. are you going to be doing any serious wheeling with that setup. if so, get some HD shafts and u-joints. the stock shafts won't hold up to much shock load with those tires.
