My Welder and what i should get next for smaller things
Discussion in 'The Garage' started by 2High4U, Dec 17, 2005.
  1. 2High4U
    2High4U 1/2 ton status
    Aug 20, 2005
    542
    Felton Pennsylvania
    What is the best all around welder for a garage things like frame repair
    to filling holes and fabwork even the little things like sheetmetal?
    I have a stick welder ill pst a pick in a couple of mins
    i was looking at http://www.lowes.com/lowes/lkn?action=productDetail&productId=189189-1703-K-2280-1&lpage=none
    what do you all think?
    I have a 220 outlet will that be fine?
    here is what i have now its pretty big and 220 not very experienced in welding but i know its too much for the little stuff used this welder one time works great for heavy thick gauge metal but im no expert
  2. stayaway
    stayaway Registered Member
    Aug 1, 2005
    59
    georgia
    I have a miller 210 and love it all the way from 22 gauge to 1 inch works real well
  3. RustyParts
    RustyParts 1/2 ton status
    May 26, 2005
    235
    Wyman, Kentucky
    I have a lincoln sp-170 which is an earlier version of the one you linked to, and I love it. I have ran 90 lbs of wire through it without a hiccup. It also has the aluminum upgrade. The only downside is that the metal needs to be cleaned of any rust to run a good bead. But I think that applies to any wire welder.
  4. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    I would stay away from the ones you can get and home depot and lowes. if you notice you only have a few settings for the heat. Regular ones will have atleast twice the adjustment for heat.
