My wife VS. new trans
Discussion in 'The Garage' started by sandawgk5, Aug 23, 2006.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I told my wife the other day that I was gonna put a NV4500 in the truck. I think I said a stick transmission so she would understand. Well long story short I cannot do it until the 700r4 breaks. It has ~180K on it and a huge cooler. It lived most of its life behind a stock 350 and followed by 3.08s and 31s. It now has 4.10s and 37s with the same weak ass 350. She then goes on to tell me that I can not purposely break it (she knows me well:D ) and she thinks it should last 250K more:eek1: . What can I do to get my NV4500 and doubler? I dont need it but who here really "needs" anything we do to our rigs:D .
    That is all
    Ira
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    swap the 3.08's back in for a while :haha:
  3. sandawgk5
    Oct 28, 2003
    6,881
    :haha: :haha: :haha: :haha:
    I dont have the 10 bolts anymore and if I did it would suk to make the gears fit in my 60 and 14FF:D
    Ira
  4. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
    start in 2nd gear all the time that'll heater up and remove the cooler ...... actually loop the lines out of the tranny together and "adjust" your TV cable
  5. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Pinch off one of the cooler lines and then do a 4 minute burnout
    That should do it :D
    Take a video too
  6. sandawgk5
    Oct 28, 2003
    6,881
    I think you missed the part about weak ass 350:D . It has as many miles as the tranny. I suppose a 4 lo with hubs unlocked could turn them pretty decent:D .
    Ira
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    dont be so obvious about it. if it goes in the next month, she'll know whats up. play with it for a few more runs, then shave some weight off of it because its too "nose heavy" start with things like your tranny cooler. 2nd gear starts, and beat the piss out of it! :waytogo:
    does it have a hitch on it? if it does, you could always hook it up to a car trailer, since your buddy needs an emergency tow. ;) then just make sure that what you put on the trailer will drag your broken truck home without problems. :deal:
  8. sandawgk5
    Oct 28, 2003
    6,881
    That is what I am thinking. I get my bonus in October and should be enough to get a bolt in NV4500 setup complete. But then I have the doubler and new HAD drivelines:D .
    Ira
  9. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    I happen to "need" every single one of my rigs and all my tools in my garage and thats a fact. :D
  10. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    I used to have an NV...
    Leave the 700 in it. Autos can be built for anything and are more multipurpose.
    My $.02
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    are you offereing to let him help you move all of your stuff to one location? now that's what CK5 is all about! helping each other out!
    (dont forget to tow in overdrive)
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    lets see... guaranteed 5.61-6.32:1 low gear (depending on trans year IIRC), or a 3.06 that through a fluid coupling, so you're not guaranteed to get that much out of it. im going to guess since he's installing a doubler, he's not just bashing through the mud, but hitting up some rocks where he needs crawl ratio. you cant beat a 4500.
    turn an auto on its side and uncover the fluid pickup... now try to power out of the situation. let me know how that works out for ya...
  13. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Give a good tug on the lockup wires so that it looks more like they got caught on something and tore off. Without the lockup working it will kill the tranny pretty quick since it will run hot now all the time without the convertor locking up like it should. :deal:
  14. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    I don't need gear ratios or a lesson on how transmissions work. :rolleyes:
    Sandawg is a friend of mine and I've wheeled with him. A built auto wouldn't be a bad choice. A doubler and two-footing it would provide plenty of control in the rocks, I believe, and if he ever wants to get over a dune, thru a mudhole, or up a wet clime, the NV can't touch an auto.
    Auto vs manual argument is as old as cars. It depends on driver pref and what he wants to do with it. There is no absolute 1 is better than the other, but and auto can be built to do things a stick can do, and behave like an auto as well. A stick is a stick, and a truck stick is big, clunky, and slow.
  15. yellowK20
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
    I agree that the debate is old and both partys have valid points but it's hard to argue the rock solid relaibility of a manual. a clutch is cheaper than a whole tranny also. BUT the auto rules in the dunes
  16. sandawgk5
    Oct 28, 2003
    6,881
    Yep I know what you where getting at. Yes I do drive with 2 feet when I am offroad and I do rock and no mud cause I hate cleaning the truck. I want a stick cause I want a stick that is the whole reason. And crawl ratio is like some of those multishock trucks. It makes up for areas where I am "lacking":D
    Ira
  17. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    you could put a small hole in the cooler lines one day and forget to check the fluid.:D
  18. sandawgk5
    Oct 28, 2003
    6,881
    Dunes scare me. I am not skilled in dunes and I get nervous if I do not make it and have to come down backwards.:o
    Ira
  19. sandawgk5
    Oct 28, 2003
    6,881
    Enough of the lounge stuff this is a tech forum bitches:D . I remember how much trouble Readymix had with the dunes and his 465 and how the auto rigs could just run em cause they would shift "automatically":D . I just have always wanted a manual but was too impatient to wait and get what I wanted now I am doing what I want. Reality is I will prolly run this thing until it dies legit. And then I will decide what to do. Nothing like jammin gears though even if the shift pattern has a 1 foot throw:D
    Ira
  20. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    nice version~just tell her you want to do it now before the tranny goes bad, that way you can sell the tranny and make a little money instead of having a broke tranny sitting around
    not so nice version~ Go grab her purse, take your nuts out put them back on and tell her thats how it is:D :haha: j/k
