Mysterious clunking...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Aug 17, 2001.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    The trans (I think) is making this strange clunking noise. If you are at idle, and hit the gas 75%, and then get right back off, the idle drops back to 700RPM (normal idle), and SOMETHING makes this noise like a wrench or something is hitting the tranny casing. Its clunks a few times, and then stops once the drivetrain is under load again. Any ideas?
    Fluid levels are all good. TH400, NP205, 454.
    <font color=red>GOT MUD</font color=red>???
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s
    <a target="_blank" href=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</a> [​IMG]
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Check your trans. mount bolts on the cross member. Maybe they came loose.
  3. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Tighten your transfer case bracket bolts or check your rear u joints.
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
  4. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Also, check all of your bushings to see if any are shot ........ If they're all cracked and brittle, replace them with either new rubber or poly ones ........huge difference !
    L8r,
  5. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Also tighten the tranny/transfer case adapter bolts. And make sure that the T-case brace is still attached to the block.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  6. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    same crap happen to me it turned out to be a bolt that came loose and feel off and was just hanging out in the cover that protects the fly wheel so you might want to take your flywheel cover off and inspect to see if theres nothing in there cuz if there is then thats the clunk clunk your hearing
    <font color=purple>I put the Panic in Hispanic</font color=purple>[​IMG]
    <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
