Mysterious Oil Leak HELP !!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rocko, Nov 12, 2000.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Okay.. I have an oil leak and it's about to drive me insane trying to figure it out. I've replaced the valve cover gaskets, that stopped it temporarily. Now it's back.. looks like it's around the oil filter base or just above.. near the oil sending/pressure unit.
    Has anyone had a problem like this? I had an oil cooler on it, that had a pin hole causing IT to leak.. So I removed the oil cooler adapter, left the lines on til I can pull the grille off to remove the cooler completely.
    So I'm thinking maybe the oil filter adapter I put in place of the cooler adapter might be bad..
    Any other suggestions before I pull out my hair?
    Thanks.
    It's better to have it than to need it, than to need it and not have it !!!!
  2. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    It could be the oil sending unit itself. A leaking sending unit is very common problem. I had a similar leak on another vehicle that was hard to pinpoint. I wiped the oil from around the sending unit real good and sprayed the area with Berryman ChemTool to get the last traces of oil cleaned off. I then ran the engine until it was fully warmed up. My leak was coming from the sending unit, and it was very obvious to see after performing the cleaning process. Good Luck
    '89 K5 Silverado 4" lift w/BFG 33's
  3. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Thanks for the info Gandolf.. That's what I was hoping it was. It looks like it's leaking above where the oil filter base is.. and below the valve covers are.
    So.. is that a dealer item? "SENDING UNIT" or is it something I can find at any parts store.
    Talk to you later.
  4. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Sending unit is probably your best bet. You can get them at any parts store I am pretty sure. You said that replaceing your vavle cover gasket solved the problem temporarily? Check your PCV valve. It may be causing pressure to build up and the oil forces its way out.
    Sparky
    78 K-5
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    You said you removed the adapter, not the cooler right? Did you plug the lines for the cooler? I did that once and didn't even think about plugging the lines and they hold about three quarts. Just a thought.
    creepin' and crawlin'
    Jim
  6. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Thanks everyone.. great suggestions thus far. I'll check it all out tomorrow. The PCV valve is new.. and the oil isn't coming from the top of the engine.. it's about midway down on the drivers side.
    Would it be a good idea to put Teflon on the oil sending unit when I replace it?
