Mysterious Squeak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by schlechto, Nov 2, 2001.
  1. schlechto
    schlechto Registered Member
    Aug 4, 2001
    56
    Carnation, WA
    Hi I have a problem. After I start my '87 GMC Jimmy, 6.2L Diesel, I start to hear a continious squeak, squeak, squeak while driving at low speeds. I think that it continues to occur at faster speeds but I can't hear it because the diesel is soo loud. However, I did find out that it stops when I apply the brakes. I don't know much about automobiles so any advice/suggestions would be a great help.
    Ben
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Maybe you have a warped rotor or two... pull 'em and get em turned, or replace them. Bet that solves your problem! Good luck!
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    <a target="_blank" href=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</a>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s
  3. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    sounds like the brakes need to be replaced...most have an indicator on them to sqeal when they wear down...pull the wheel off and check them.
    When you apply the brakes the pressure makes them stop vibrating..if you go to your local parts store they can show you and explain better. Most likely new pads and have the rotors turned.
    chris
    MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM![​IMG]
