mystery hose
Discussion in 'The Garage' started by vortec, Apr 26, 2005.
  1. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    maybe someone can tell me what this is. in my '82 k5 5.7L, i found an open-ended hose hanging behind the brake pedal. same type hose as the larger vaccum lines underhood. it runs back behind the dash insulation, so i can't see if it passes through the firewall. i'll check under the hood better tomorrow when i have sun and no rain, hopefully. is it maybe a drain for a/c condensation? bad location, if so.
  2. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
  3. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Does it have vacuum with the truck running?
  4. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    It might be for the cruise control, if you have/had cruise control.
    My 88' and 86' have a large vacuum hose that runs from cruise control actuator, up under the dash to the control module.
  5. dyeager535
    26,980
    Sounds like cruise to me. Usually goes through the firewall wrapped/taped together with the wires for the cruise control, if you have the electric cruise, and not the transducer on the driver side fender with the speedo cables going into/out of it.
  6. sweetk30
    Nov 1, 2004
    25,544
    540
    horseheads , ny 14845
    haha i removed my cruise and then had vac leak when brakes hit . i thaut i had a bad booster but was the hose sucking air.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    definitely cruise brake switch hose
  8. vortec
    Jul 22, 2004
    1,472
    fort worth, texas
    no vac with engine on. i do not have cruise control, to the best of my knowledge, unless they were really inconspicuous on these old trucks. no button for it or anything.
  9. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Mine was on the turn signal switch on the tip, just a small button on the end that is hardly noticeable...this is on a '77 btw.
    __________________
    '77 K5, Warn M8000, 402/350/203, 44/14bff, 4"/36" Irok's
    http://www.krazyk5.com
    http://community.webshots.com/user/trcksr4me
    http://community.webshots.com/user/trcksr4me2
  10. dyeager535
    26,980
    And you can easily yank the cruise lever out and replace it with non cruise.
