Mystery: How can this happen?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blue85, Feb 28, 2004.
  1. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,090
    489
    Grand Rapids area
    I am not sure what happened yesterday. In my normal state of wheeling /forums/images/graemlins/k5.gif, I came to a stop light (sense sarcasm?). When the light turned green, the truck was clearly in neutral. I tried shifting through all the gears (700R4), got out to make sure the rear driveshaft was still there and locked the hubs. I was very unpopular. Still nothing in 4HI. Did I blow the tranny, lose all the fluid or blow the T-case? /forums/images/graemlins/confused.gif Shifting to park caused a ratcheting noise which I knew was the parking pawl. The problem was the transfer case. I thought about rebuilding it with a Dodge fixed yoke (NP 208) /forums/images/graemlins/grin.gif. Then I shifted to 4LO and could feel the truck drop into gear. So the NEXT green light, I drove it into the corner gas station in 4LO, expecting to hear parts grinding and scattering. But it was fine. I shifted back to 4HI and 2HI and both worked. /forums/images/graemlins/confused.gif I drove home and floored it after a couple more lights and everything worked perfectly. I tried moving the T-case shifter all around and brake torqueing and could not duplicate the condition.
    What could have caused this? If the shift linkage goes further forward than the 2HI position, can it disengage the drive path through the 'case? Is this a sign of worn shift forks or something? I've never had any problems with this transfer case before.
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Sounds like your transfer case came out of gear. /forums/images/graemlins/waytogo.gif
  3. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    Sounds like the T-case found 'N' all by itself. Could be worn shifter parts, or even the plastic tabs on the range fork. Could also be a weak detent ball spring on the T-case side of the shifter assembly.
    Rene
  4. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    your shifter might be out of adjustment or maybe you have worn engine/tranny mounts and that caused it to pop out of gear. /forums/images/graemlins/dunno.gif
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    my truck did the EXACT same thing when i had the 700/208 combo in it...When I swapped the 465/205 in I pulled the 208 apart and one of the forks (the mode fork I think) had been grinding against the planetary gear and was FUBAR'd and it would slip into neutral...Oh yeah, those little nylon pads were in about a million pieces in the botton of the case...
    Chris
  6. Blue85
    Jul 26, 2000
    9,090
    489
    Grand Rapids area
    Thanks, that's good info.
    As an update, it did it to me again, this time after a hard stop. Thinking back, the first time may have been a hard stop, too. I will adjust the linkage a bit to see if it helps, but I am starting plans for a 208 rebuild.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have a known good 208 with adapter if you need it, PM me if interested.
  8. offroad87
    offroad87 Registered Member
    Feb 2, 2004
    57
    Atoka, TN
    last night when was leaving a stop light I gagged the throttle, i broke the slip yoke,(anybody have a good one they want to get rid of?) brand new Ujoint, and cracked my 208 all the way around. i already found another 208 though. how difficult are they to rebuild?
  9. ford_assassin
    ford_assassin 1/2 ton status
    Nov 8, 2003
    101
    Bakersfield, Ca.
  10. Blue85
    Jul 26, 2000
    9,090
    489
    Grand Rapids area
    Mystery solved. [​IMG]
    The destroyed range fork was allowing the planetary gearset to go into neutral without the shifter actually moving. While the total shift pattern is 2H, 4H, N, 4LO, that actually comes from two places. The mode fork selects 2WD/4WD by engaging the drive sprocket for the chain. The range fork changes the configuration of the planetary gearset to select HI, N, LO. I was skipping from 2HI to N because the mode fork was fine, but the deceleration force from braking hard was pulling the planetaries forward enough to disengage them.
    I modified the fork on the left (Ford style) to take Chevy style fork pads, used serious glue on the pads and problem solved!
    I believe the original problem was misadjusted shift linkage, probably from lowering the T-case without readjusting the linkage. Just because I still had all 4 modes didn't mean everything was running right, I guess.
    I did a slip yoke elimination on the 208 at the same time.
