n000b. Throttle sticking
Discussion in 'The Garage' started by Ben B., Mar 6, 2007.
  1. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    My throttle started sticking like a bitch, even just under normal driving conditions. When I got home i took off the aircleaner to check out the carb so put a return spring on it, but it already has one. What could be making it stick and how do I fix it?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    worn out throttle shaft. see if you can wiggle the throttle shafts any.
  3. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Thottle cable binding, gas peddle binding, weak spring(s), broken spring, carb problems.
    Disconnect the throttle cable and see if you can feel any resistance in movement on the cable, peddle or throttle lever itself.
    May tell you where to look.
  4. JohnDeere
    JohnDeere 1/2 ton status
    Jan 17, 2006
    342
    Houston, Texas
    Mine was just sticking it turned out that my choke was causing it some how it got lose and got turned so it was causing my throttle to stick.
  5. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    if you pulled of the carb recently and replace the gasket...to small of one can cause the butterfly thingsy (botom) to get caught in it...
